Running on one cylinder - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 8 (permalink) Old 01-05-2009, 03:03 PM Thread Starter
My 1984 Yamaha Phazer is running on one cylinder. I have already put new plugs in and a new ignition coil. The cylinder is getting gas because it is very wet but not firing. I assume that it is an electrical problem but am having a very hard time determining what it may be. Any advice would be greatly appreciated.
1986 Yamaha Phazer
1988 Yamaha Bravo
1990 Yamaha Phazer II
1992 Yamaha Phazer II
1996 Yamaha VMAX 500XT
rippintheyammi is offline
post #2 of 8 (permalink) Old 01-05-2009, 09:37 PM
Are you SURE it's not firing? Use an inline spark tester to verify.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #3 of 8 (permalink) Old 01-05-2009, 10:26 PM Thread Starter
I am sure it is not firing because it sounds like my yamaha bravro. I have also taken the cap off of the bad plug to see if there is any change. I am 100% positive it is running on one cylinder, I just can't figure out why. Any help or suggestions are appreciated.
1986 Yamaha Phazer
1988 Yamaha Bravo
post #4 of 8 (permalink) Old 01-06-2009, 06:45 AM
I understand that. I need to know if there is actually spark on that plug wire. Check it with an inline spark tester.
1999 Ski Doo MXZ600
post #5 of 8 (permalink) Old 01-06-2009, 12:05 PM Thread Starter
There is no spark on that plug. What route would you suggest I take?
1986 Yamaha Phazer
1988 Yamaha Bravo
post #6 of 8 (permalink) Old 01-07-2009, 07:39 AM
Replace that coil. If you already did, did you replace the spark plug boot or reuse the old one?
1999 Ski Doo MXZ600
post #7 of 8 (permalink) Old 01-07-2009, 07:43 PM Thread Starter
The spark plus boots were replaced along with the coil. Could it be the CDI? I just really have no idea what to do beyond replacing the ignition coil.
1986 Yamaha Phazer
1988 Yamaha Bravo
post #8 of 8 (permalink) Old 01-08-2009, 05:29 AM
The CDI serves BOTH cylinders, so if it was bad, the sled would not run. Assuming you did indeed use a spark tester, I don't know what's next. Did you do a compression test to be sure the compression is OK?
1999 Ski Doo MXZ600
