Spark Plug Torque? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 14 (permalink) Old 10-26-2008, 04:07 PM Thread Starter
FORGET WORK- I WANNA PLAY
TCOLLINS's Avatar
Spark Plug Torque?
Does anyone know what to torque spark plugs to?I don't usually use a torque wrench but would like to make sure they are correct.
1998 Polaris Indy 500
1996 Yamaha Vmax 600
1991 Yamaha Phazer II48
1986 Yamaha SRV 540*Freebee*
TCOLLINS is offline
post #2 of 14 (permalink) Old 10-26-2008, 04:44 PM
Ultrafrozen's Avatar
Use "turn of nut" method as described on package.
Ultrafrozen is offline
post #3 of 14 (permalink) Old 10-26-2008, 06:41 PM Thread Starter
TCOLLINS's Avatar
I know the package says 1/2 to 5/8 turn with washer and 1/8 without. But my Polaris manual says 11 foot pounds.
TCOLLINS is offline
post #4 of 14 (permalink) Old 10-26-2008, 07:50 PM
Looks like you answered your own question.
post #5 of 14 (permalink) Old 10-26-2008, 07:55 PM Thread Starter
TCOLLINS's Avatar
Not really. The NGK website says 18 to 21.6 lb ft. for 14mm aluminum heads. That seems pretty tight to me.
TCOLLINS is offline
post #6 of 14 (permalink) Old 10-26-2008, 08:49 PM
Use a torque wrench to see how many ft-lbs 1/2 to 5/8 turn creates.
Polaris service manual says 11 ft-lbs with threads lubricated with anti-seize compound. Maybe NGK lists their torque value with dry threads.
I know with structural steel bolted connections, lubrication is not recommended because of possibility to overtorque the bolt assembly. Could explain the lower Polaris value.
Hope this helps.
post #7 of 14 (permalink) Old 10-26-2008, 08:53 PM
On Wisconsin!!!
Octane's Avatar
Just snug 'em up. You basically want them just a little bit tighter than finger tight. Just make sure that you dont go crazy torquing the plugs because it doesnt take much to strip out aluminum, especially if the engine is warm when you tighten the plugs.
When you say Wisconsin, you said it all.
'01 Polaris Indy 600 XC SP EDGE XR
Powermadd articulating bar riser with 2" riser block (total rise of 4 1/2")
Pro-X seat
red Cobra low sno-x windshield
Pure Polaris handguards with Pure Polaris mounts
almond/blue drive clutch spring with 10-60 weights
121" x 15" x .91" track with 96 studs.
7,300 miles
Citgo Sea and Snow oil
Octane is offline
post #8 of 14 (permalink) Old 10-27-2008, 07:32 AM
If it has a washer, get it snug, then go another quarter turn. It ain't rocket science.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #9 of 14 (permalink) Old 10-27-2008, 04:58 PM Thread Starter
TCOLLINS's Avatar
No shit. Just asking a few questions. That is the purpose of this site, RIGHT?
TCOLLINS is offline
post #10 of 14 (permalink) Old 10-27-2008, 06:19 PM
Alaskan Member
Skligmund's Avatar
I'd go with Polaris' recommendations, as they use NGK from the factory, and they have a spec for it. I personally just put them on there using my calibrated elbow.
Polaris 580/597/600 crank info: http://www.geocities.com/schmidt92/polaris_faq.html
Skligmund is offline
post #11 of 14 (permalink) Old 10-27-2008, 10:30 PM Thread Starter
TCOLLINS's Avatar
Ya, thats what I normally do but when i was thumbing through the polaris specs it said 11 ft lbs. So when I was bored I decided to check and where I thought was tight was not even close to the 11 ft lbs. I was probably half or less of that. Just learning about sleds . I can admit I am not the most knowledgable mechanic if I was I would not visit this site to knock others. Anyway thanks for the helpful advice.
TCOLLINS is offline
post #12 of 14 (permalink) Old 10-27-2008, 10:36 PM
Alaskan Member
Skligmund's Avatar
Keep it loose enought o be able to remove them with the toolkit supplied plug wrench! IMO, if your hands are kinda cold, and you need to change a plug, and the plug is to tight, you have issues. So keep that in mind, and you might torque one down and see if you can remove it with the little wrench. If you can't I'd set it to the highest that you can remove it. Make sense?
post #13 of 14 (permalink) Old 10-28-2008, 12:32 AM
IndianRvrShiver's Avatar
Don't get over sensitive, mon!! It's just a frickin' spark plug....shoot, I 've seen guys tightening them with a pipe wrench & guess what? The sled ran fine!!
Good advice from Sklig!!
IndianRvrShiver is offline
post #14 of 14 (permalink) Old 10-28-2008, 05:21 PM Thread Starter
TCOLLINS's Avatar
I'm sorry I asked about the DAMN plug torque.Screw it. Sleds run fine.I'll stick to tightening them the old way.Who needs a torque wrench anyway. PLEASE NO REPLIES ON THAT ONE!
TCOLLINS is offline
