08-03-2008, 10:05 PM
exhaust and engine question
i am trying to get rid of some weight on my 90 wildcat 650 can i gut the exhaust can without rejetting the motor or anything?? also i want to try an put a sled engine in a gokart or golf cart, at least a 440 cc can i run a fan cooled engine in the summer or does it have to be liquid cooled?? also prolly want an engine where the exhaust goes from 2 to 1 for space reasons, any opinions or pointer are appreciated thanx brandon also if anyone has a set of nice used plastic skis that would fit my wildcat let me know, thanx again
08-04-2008, 06:10 AM
Above The Arctic Circle
Most cans do not reqiure re-jetting. But IMO they really dont do anything but make noise. Your probably only going to lose like 5 pounds or somthing. For your golf cart a fan cooled would be great and you could run a liquid but you would have to find a rad for it. I would suggest going with a fan it would be alot easier to work with.
01 Polaris RMK 136"
- 01 600 VES Engine - Uni Air Filters
- Sno Stuff Rumble Pack - Powermadd Boost Bottle
- Custom Painted Hood - Powermadd Bar Riser
- EPI Pro Series Clutch Kit - Xtra-10 rear suspension
01 Yamaha VK III 540 ( The TANK)
Out Of Commission Till Next Year
08-04-2008, 09:04 AM
The silencer on the 650 is quite large and weighs about 10 #
If you can get one from a newer sled (93/94), they weigh half as much.
08-04-2008, 11:23 PM
so i dont need to rejet the carbs if i gut the can?? also do i need a sway bar in the front, one of the links broke and was wondering if i need it? does it handle better with or without it? thanx brandon
08-05-2008, 07:26 AM
DON'T GUT THE CAN! You'll lose back pressure and burn the exhaust side of the pistons! Get a newer silencer to put on it. Do it right, the FIRST time!
08-05-2008, 08:17 AM
As SEG said, do not gut the can, get one from a newer model Wildcat as it will be half the weight.
You can run it without the stabilizer bar, it just won't corner as well since both skis will not stay planted. The inside one will tend to lift in hard cornering, resulting in "pushing" in the corners.
Fix the link!
08-28-2008, 08:08 AM
I agree with the guys! As for the cart a 500cc fan from like a cougar will be perfect! But you want to get the hole sled, to be able to use the diven clutch, as well as the brakes!
To loose weight on a Wild Cat is still a ongoing quest! Loose the track get a newwer one can save 20# or more! Plastic or Alum skis another 10-15# ! The seat foam, the hood,the shocks, the suspension in general are all places you could shave a few more!
08-30-2008, 01:46 PM
Maybe it's you that needs to loose weight, not the sled! :-)
08-30-2008, 09:07 PM
hey thanx alot
08-31-2008, 04:00 PM
No problem, haha! Just playing around!
