bearing housing
I put in new bearings in my 2000 zl580esr last spring, put 40 miles on it this year and speedo went out again, so i took it to my buddy he checked everything and found something weird, the bearing housing while it is in the sled is offset in the position. so when he adj track the leftside adj is out more than the right, which after running the sled ion stand, speedo adapter breaks. so that means the shaft isnt square. what could be the issue???? there is no signs of wear on the tunnel or where the bearing holder fits, the bolts are all tight and fit good.(nothing is ovaled or wore) could there be something wrong with the bearing holders? you can see the outer one is not center in the frame hole where it sits........
thanks for the help
2000 Arctic Cat ZL580 ESR
Carleton, MI
Ride area: Long Lake, MI
