whats a stator? - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 9 (permalink) Old 11-18-2006, 12:56 PM Thread Starter
whats a stator?
What does a stator do? Is it similar to a distributive cap?
ncorrieri is offline
post #2 of 9 (permalink) Old 11-18-2006, 05:13 PM
It's basically a coil that generates electricity when the flywheel magnets spin around it. The number of coils determine the voltage.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #3 of 9 (permalink) Old 11-18-2006, 06:46 PM
IndianRvrShiver's Avatar
More like an alternator than a distributor cap.
IndianRvrShiver is offline
post #4 of 9 (permalink) Old 11-19-2006, 03:21 PM
Quoted: 102 Post(s)
Exactly like an alternator; it generates alternating current. It has to be rectified and regulated to make 12 volt DC for any 12 volt DC applications on a sled...
BC_Dan is offline
post #5 of 9 (permalink) Old 11-19-2006, 09:30 PM
Kemo's Avatar
Stator, meaning stationary. It'd be pretty much backwards as to how a distributor works. In this case, the stator would be the rotor, and the flywheel magnets would be the cap. Except, in our case, the cap (flywheel) spins, and the rotor (stator) doesn't. Magnetic fields conduct electricity, I went through ignition systems last year... LONG class i tell you.
In order to convert ac to dc, gotta have diode rectification. How many diodes you need, depends on how many phases your AC source is. For 3 phase, you need 6 diodes to convert AC to DC voltage. For 6 phase, 12 diodes.
Kemo is offline
post #6 of 9 (permalink) Old 11-20-2006, 09:08 AM
JD
TUGHILLYAMMI's Avatar
Pretty much to sum it up CHARGING SYSTEM
TUGHILLYAMMI is offline
post #7 of 9 (permalink) Old 11-20-2006, 09:54 AM
Not quite a charging system, than a trigger system for the ignition and coil for the lights.
1999 Ski Doo MXZ600
post #8 of 9 (permalink) Old 11-20-2006, 09:52 PM
rgoers's Avatar
In a nut shell... it's basically a mini generator. It works by passing magnets over a coil (or several coils) to generate alternating current.
A distributor is pretty much just a multi-position switch. Not the same as a stator at all.
2004 Polaris Trail RMK 136
1997 Ski Doo Summit 500
rgoers is offline
post #9 of 9 (permalink) Old 10-13-2009, 02:15 PM
Blaine1's Avatar
Here are a couple of videos that show how to test a stator and how to remove and reinstall:
Stator testing out of a sled
YouTube - Stator Testing a 2 Stroke Stator
Stator testing in a sled:
YouTube - Stator Testing in a sled
Stator removal:
YouTube - Installing a Stator Pt.1 Removing it
Stator reinstall:
YouTube - Installing a Stator Pt.2 Putting Everything Back Together
Blaine1 is offline
