Old 12-28-2008, 08:18 PM   #21 (permalink)
sledder1985
i would be riding but...
sledder1985's Avatar
anyone know the plug type for a 1972 arctic cat panther 440?
1994 polaris xcr 440
www.atv-forum.com
sledder1985 is offline   Reply With Quote
Old 01-02-2009, 11:17 AM   #22 (permalink)
Rappid
Does anyone know the spark plug gap for a 1999 Polaris Indy 600?
Thanks
Rappid is offline   Reply With Quote
Old 01-30-2009, 08:58 PM   #23 (permalink)
Lind
if your on the trail and you want to know always have a set of spark plug wrenches, screwdriver, pylers and a dime. the dime is about the size that your spark plugs should be gapped
Lind is offline   Reply With Quote
Old 01-31-2009, 05:32 AM   #24 (permalink)
0.028
Old 02-25-2009, 10:46 AM   #25 (permalink)
minx163
minx163's Avatar
Originally Posted by 95_polaris_indy View Post
i have a 95 polaris indy trail and i got new plugs from the dealer and they gave mw br8eix, and i just looked it up on the form and ngk calls for br9eix i know the 9 is a hotter plug but what would be good for my sled or what is suppose to be in it?
Jap plug, larger number colder plug. American which is what you should be using "support the economy buy domestic" Larger Number hotter the plug.
minx163 is offline   Reply With Quote
Old 04-28-2009, 07:32 PM   #26 (permalink)
oilguy
good info
AMSOIL Guru:
www.lubedealer.com/order/
oilguy is offline   Reply With Quote
Old 10-14-2009, 08:53 PM   #27 (permalink)
Blaine1
Originally Posted by smallengineguy View Post
My plugs look like #19. My burn mark is about 1/16th up the electrode at 50mph and at long WOT blasts. Good pictoral of used plugs to show the ranges.
Old 10-14-2009, 09:42 PM   #28 (permalink)
justmytailights
ngk= higher the number the colder the range
champion= the lower the number the colder the range
the insulator determines state of tune: good,pre-ignition,detonation
the flat where the ground is welded determines jetting:
wet= rich
dry = good
oily =rings or too rich oil mixture
grey=lean
also not that if the rings are bad or if you have a cylinder that is bad,the sled will run until it gets warm then shut down due too loss of compression.this is because of an abundance of oil in the rings which promotes compression until combustion burns it away then very little compression and sled won't start.
justmytailights
justmytailights is offline   Reply With Quote
