Fuel pump not stuck just bought sled guy I bought it from replaced stator said it ran great 20 min then died.when I hook pump up to 12 volt sled starts up and runs great lights and everything else work fine
No, the voltage requirement is differentfor the EFI.
It uses a lower load than the headlights.
Test the output to the ecu from the regulator, it might just be a blown fuse link.
Here is what I have the red plugs into orange one if I jump fuel pump it runs the wires from computer put out power when running I get nothing out of red wires coming from stator
Ok!
I would pop the flywheel off and see if you have all the magnets on your flywheel!
Related Threads
Snowmobile Forum
630.8K posts
58.1K members
Since 2002
