Custom fabricated cleats - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-07-2013, 02:20 PM   #1 (permalink)
RawRider90's Avatar
Custom fabricated cleats-imageuploadedbysm-free1357589514.239935.jpg what I was thinking is to take 1x1x1/8 aluminum angle and put sections every 8-12 inches just on either side of the drive gear holes in like 7inch lengths because I cannot get a heavy cleated track!
Opinions?
RawRider90 is offline   Reply With Quote
Old 01-07-2013, 02:47 PM   #2 (permalink)
I would not use aluminum, too soft.
Old 01-07-2013, 02:49 PM   #3 (permalink)
RawRider90's Avatar
Steel? But then I run into weight issues I don't want to overload on weight I will be replacing track next season but will be doing something similar next season
Old 01-07-2013, 05:34 PM   #4 (permalink)
Ultrafrozen's Avatar
Is there enough space around the track drive shaft?
Gallery Pictures.
Current Sleds: A few
Old 01-07-2013, 05:35 PM   #5 (permalink)
RawRider90's Avatar
That's what I'm looking at tonight
Old 01-07-2013, 08:04 PM   #6 (permalink)
Contact Joe at Central Wi Track Repair! He can actually ADD lugs!
Old 01-07-2013, 08:30 PM   #7 (permalink)
RawRider90's Avatar
Ok is there an add a lug kit available?
Old 01-08-2013, 06:41 AM   #8 (permalink)
No it is a fairly complex process! Call and talk with Joe (715) 570-7378!
What sled is this?
Old 01-08-2013, 07:42 AM   #9 (permalink)
RawRider90's Avatar
72 Yamaha sl338
Old 01-08-2013, 11:07 AM   #10 (permalink)
I had an old 197? Snowbug sled that had aluminum TEE bar cleats. They were about 32" long and were used to tie three separate rubber belts together like the old style tracks.
I'll see if I still have pics and post them tonight.
Gallery Pictures.
Old 01-08-2013, 12:02 PM   #11 (permalink)
RawRider90's Avatar
Awesome thanks that would give me a better ideaCustom fabricated cleats-imageuploadedbysm-free1357668134.820907.jpg I was think something like this
Old 01-08-2013, 12:13 PM   #12 (permalink)
RawRider90's Avatar
Awesome thanks that would give me a better ideaAttachment 20166 I was think something like this
Old 01-08-2013, 05:27 PM   #13 (permalink)
That IS a 2/3rds cleated track! They even hadm a FULL cleated track, but it wouldn't turn! Kinda like a 4 wheeler with a straight axel or an old Honda Oddesy!
Old 01-08-2013, 05:28 PM   #14 (permalink)
So what type of raceing are you going to do? Drag, oval, sno cross, cross country, hill climb?
Old 01-08-2013, 05:32 PM   #15 (permalink)
RawRider90's Avatar
Ill be using it for joy riding so a bit of everything and also pulling a small groomer
Old 01-08-2013, 05:33 PM   #16 (permalink)
RawRider90's Avatar
And I'm not sure about that track I found that online
Old 01-08-2013, 05:35 PM   #17 (permalink)
The older ones were full width but this was from a newer Snowbug with the split cleats. They found the full 32" cleats would crack in the middle so they just made them that way. Stock cleats were rivetted with an aluminum backer plate. You can see bolted replacements in the pic.
Gallery Pictures.
Old 01-08-2013, 05:53 PM   #18 (permalink)
If your track is good, just add Stars with a center Carbide stud!
Old 01-08-2013, 06:30 PM   #19 (permalink)
RawRider90's Avatar
I like the t-stock! Stars?
Old 01-08-2013, 07:02 PM   #20 (permalink)
Keep in mind, this was on an 18HP sled.
Gallery Pictures.
