1993 Alpine II - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-07-2013, 08:36 AM   #1 (permalink)
1993 Alpine II
I have an Alpine II and the steering is extremely hard to turn. The ski has a coil spring and a shock but they do not seem to work, the shock is stiff as a steel rod. I was also thinking on riveting strips of polymer plastic under the ski to keep it from sticking to the snow when I stop for a while. Any suggestions???
Thank you,
J-P
jeepee is offline   Reply With Quote
Old 01-07-2013, 08:39 AM   #2 (permalink)
Is it hard to turn when the front end is lifted off the ground?
Old 01-07-2013, 09:17 AM   #3 (permalink)
Alpine II
When the front end is lifted off the ground, it is easy to steer.
Old 01-07-2013, 02:48 PM   #4 (permalink)
Ok then, the issue is that you have too much ski pressure.
Increase the front skid spring pre-load a bit.
Old 01-07-2013, 04:15 PM   #5 (permalink)
Alpine II
Correction, I got the front end off the ground and the ski is still stiff to steer.
Old 01-07-2013, 04:18 PM   #6 (permalink)
To RJ Gleason,
I see on your reply a note at the bottom, are you a SW of 472?
Old 01-08-2013, 07:26 AM   #7 (permalink)
Yes I am.
Since the steering is stiff with the skis off the ground, then you need to go through and grease where it has fittings and lube the heim joints.
Old 01-08-2013, 07:30 AM   #8 (permalink)
Alpine II
Thank you for the tip. You have not answer my second question.
J-P WWM
Old 01-08-2013, 07:32 AM   #9 (permalink)
Yes I am.
Old 01-08-2013, 07:41 AM   #10 (permalink)
Alpine II
I feel reassured that I will be getting the best advises.
