Old 02-28-2005, 04:50 PM   #1 (permalink)
ultrafast
ultrafast's Avatar
bogey wheel
hey i have a 1997 ultra and i need to take off my inside bogey wheel that is near the shock that is closer to the front of the sled, so that i can then replace the plastic and metal things inside the wheel. i believe i broke this going over moguls in old forge. my question is, does anything know if im going to have to take off my whole track and the shock? because i tried just taking the bolt out but it doesn't seem to come out this way.
ride hard, you can rest when you die
ultrafast is offline   Reply With Quote
Old 02-28-2005, 05:55 PM   #2 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
the bolt probly is just rusted in.
http://www.hiperf.com/
Old 02-28-2005, 07:22 PM   #3 (permalink)
rgoers
rgoers's Avatar
There's usually a sleeve in the bearing. Bolts are notorious for rusting to the sleeves... It's a real pain to get them out. I usually end up cutting the bolt off with an angle grinder, and just replacing it. It will save you hours of beating it with a hammer!
2000 440 Panther
1980 Jag 3000 F/C
Old 03-01-2005, 08:24 AM   #4 (permalink)
bobo
pull the skid. alot easier to work on stuff when it's right there in front of you.
bobo is offline   Reply With Quote
