Old 02-26-2005, 01:02 PM   #1 (permalink)
snonut12
Carbides/studs
I looked up the Woody's website and this is what they recommended for my sled:
POLARIS - 600 XC SP 50TH (2005)
BASIC INFORMATION
Track Length 15 x 121"
Lug Height 1.250
Tunnel Protection Standard
TRAIL APPLICATION
Stud Length 1.325
Stud Quantity 120
Recommended Runner(s):
6" 60 DEGREE CARBIDE TRAIL BLAZER IV TPI4-8125
Recommended Dooly(s):
6" 60 DEGREE CARBIDE DOOLY DP6-8125
INTERMEDIATE APPLICATION
Stud Length 1.325
Stud Quantity 144
8" 60 DEGREE CARBIDE EXECUTIVE SERIES WPI-8125
8" 60 DEGREE CARBIDE DOOLY DY8-6580
PERFORMANCE APPLICATION
Stud Length 1.325
Stud Quantity 168
Recommended Dooly(s): N/A
I occusionally like to ride aggressively with some trail riding so I think intermediate application would be the right one? I originally would like to put 96 studs but Woody's recommend 144. I don't know about the carbides part... should I go with 6" or 8"? Keep on mind that I have 1.25" track.
Can you explain how I should select the stud type - single and double? I'd like to keep the studs to inside track only so it'd be easier to slide in turns and less chance of ripping apart the track. I looked at Woody's template diagrams and there are a couple different patterns to keep all 144 studs to the inside section of track. The first one has three single studs on each line and the other has two single studs on one line, and two double studs on the next line. What is the difference in performance? Which would be better? Thanks.
Stephen
snonut12 is offline   Reply With Quote
Old 02-26-2005, 07:35 PM   #2 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
well I would recomend you just stick with the 96 and 6inches of carbide. You are right on the money about keeping the studs to the inside, are you sure you can put all 144 in the middle? Also I would go with the double backer patteren, they hold the studs straighter than he singles do. Also get some support nuts so you studs wont bend. Personaly I like stud boy.
http://www.hiperf.com/
Old 02-27-2005, 10:30 PM   #3 (permalink)
snonut12
Thanks for your suggestion. I just thought that 144 would be a bit of overkill so that's why I asked. Anyway 96 studs and 6" carbides will be what I'm looking to upgrade.
Stephen
Old 02-28-2005, 08:07 PM   #4 (permalink)
ITriumph
F.K.A. MOUSE72
ITriumph's Avatar
Iwas looking at my buddies owners manual for his sled, and it had stud diagrams in it. Take a look at your owners manual and see what the factory recommends
snow and ice imagery
extended forecast for Alanson
And on the eighth day, god created snowmobiles .
ITriumph is offline   Reply With Quote
Old 03-06-2005, 04:31 PM   #5 (permalink)
SnowRida
Runnin Against The Wind!
SnowRida's Avatar
96 should be just fine.
SnowRida
Yamaha V-Max
02 MXZ 600
97 Polaris Indy Trail Touring
Old 11-06-2009, 04:30 PM   #6 (permalink)
Darrin2230
I've got a Yamaha Apex GT with a 121 x 15 x 1.25 and the local tech recommended 168 6" trailblazer carbides for me. 168 on a 121 seems like way too much unless you're racing or need super performance. My riding is, like the rider below... mostly trail riding with the occasional aggressive riding.
Thoughs? Thanks for your feedback.
-Darrin
Darrin2230 is offline   Reply With Quote
Old 11-06-2009, 04:37 PM   #7 (permalink)
120 would be enough.
