» Site Navigation
» Power Sports Links
Old 11-13-2003, 03:45 PM   #1 (permalink)
Smile trail grabbers ortrack lug studs
are they good bad ? are they better are worse than studs? will they wreck my 1 3/8 track. do they work good on ice? thanks
f7mn is offline   Reply With Quote
Old 12-17-2003, 07:40 PM   #2 (permalink)
rollinredcavi's Avatar
listening....
I am gona do a lot of ice fishing this year and I will need studs for my sled to do anything on the ice. I think these will work fine. If you ask a lot of people they will tell you no. But these are also the guys that have used push through studs forever. think about this in a physics sense.
If you have a track that is.. say 1 inch lugs. this means that you would get studs 1 1/2 inches long. If you use the lug studs you will have a 1/2 coming out of the track. So if you think about the physics on this one, which one will create the greatest stress on the track? the 1 1/2 of course, about 3 times the force on the track to be exact.
I do think that they may pull out easier but they will definatly cause less damage when they do.
rollinredcavi is offline   Reply With Quote
Old 12-17-2003, 11:37 PM   #3 (permalink)
Team Arctic
you should NEVER use 1.5" studs on a 1" lug track, thats crazy, unless you like tearouts every 5 minutes. if you have a 1" lug you should be runnin 1 1/8" at most.
Founder/CEO
Fusionetworks Inc.
2001 Arctic Cat ZR600EFI
--Wiseco Pistons, VF3 Reeds, MBRP Race Silencer, D&D Clutch Kit, C&A Ultra Pro skis, 4" Handlebar riser, (4) D&D Bullseye Air Intakes
Looking for 04-06 L/C ZR440 SnoPro (race model)
Maverick is offline   Reply With Quote
Old 12-18-2003, 06:47 AM   #4 (permalink)
sorry,
I realized that I posted wrong numbers after I had left and got thinking about it. Either way though, the push through studs are going to cause more stress on the part of the track that they are on.
Shouldnt it be a quarter inch over the lug though? at least thats what I thought was the normal.
Old 12-18-2003, 12:21 PM   #5 (permalink)
JimmyV's Avatar
1/4 inch is fine.
I'm coo coo for freakin coco puffs!
JimmyV is offline   Reply With Quote
