In my experience, the higher you can get the back end off the ground, the better! I've done the long track on my Panther twice by myself! Easy as cake, if the rear is up high enough. I just put a piece of ply on the top of my floor jack, and jack it into place. Don't forget to take sesnopro's advice and DO NOT attach the rear springs until all the tunnel bolts are in. Having the back up high enough allows you to swing the springs out of the way too...
2000 440 Panther
1980 Jag 3000 F/C
