Nope... if you run in powder, all the studs will do is tear up your trailer/driveway/garage.
If you've got the $$$ to stud it... I'd go buy another track with bigger paddles. For the conditions you described, you'll spend about the same, but the new track will *definitely* help you hook up - way more than studding will!
2000 440 Panther
1980 Jag 3000 F/C
