If you take the suspension out, it also gives you a chance to look at all the cross bars and check out the bearings on all the wheels.
If you do take it out, to reinstall, do the front bolts first, then the rear. If the rear has gas charged shocks, put a ratchet strap around some of the suspension parts to help collapse the suspension so the back ones will line up.
