If I drop the top mount out and then turn up the suspension, wont it have to be depressed to fit back into the slot? I was also wondering..It looks like there is two screws with notches on it. Is it like a lock bolt, where I unscrew the first bolt, then tighten the main screw. When i have it where I want it, I put the second screw back to prevent it from backing off? thanks for the help
