Old 08-04-2008, 11:26 PM   #1 (permalink)
bdavis1
wildcat sway bar
one of the links that go from the sway bar to the upper control arm broke, do i need a sway bar will it handle better without or no?? thanx brandon
bdavis1 is offline   Reply With Quote
Old 08-05-2008, 05:35 AM   #2 (permalink)
Better with.
If you don't mind the inside ski lifting on tight corners, you can do without it.
Old 08-09-2008, 12:54 PM   #3 (permalink)
~baker~
~Baker~
~baker~'s Avatar
ya want to keep your sway bar. when my sway bar links broke "right where the tie rod end mounts on" on my 91 ext it was alot different riding without the sway bar. The arms are only around 55$ each there not much I bought 2 for mine.
Brandon Howard Baker #10
Owner of:
- 1991 Arctic Cat El Tigre EXTerminator 550 Mounatan Mod Special......Clutched, Wiseco pistons, 136 x 15 x 2 1/4 track, custom tunnel extension, Custom dash, custom can, Fox Shox, pro-tapers, 5in Rox riser, powermadd hand guards, RSR pull cord handle, OBI grips and bar ends, custom brake light, custom brake leaver, painted front end
- 1990 Arctic Cat Super JAG
- 1974 VW Dune buggy "16000cc of brute
~baker~ is offline   Reply With Quote
