» Site Navigation
» Power Sports Links
Old 03-06-2004, 08:16 PM   #1 (permalink)
Member
thesweeper09's Avatar
Studding F6???
My friend has a 2004 FireCat F6 and i plan on spring ordering a 2005 SnoPro F6 EFI.... i was just wondering cuase i heard from a few peeps that studding the track might cause too much pushing and wont let you steer as good cause all it wants to do is drive forward..... is this true?? the snopro has a 1.375 inch track... if i add studs to that will i affect my steering?? what if i only put 48? or 96 studs??
thesweeper09 is offline   Reply With Quote
Old 03-06-2004, 11:51 PM   #2 (permalink)
RoloCade's Avatar
Depends on the length of the carbides up front. 96 studs would be 8-10 inch carbides up front. If they only run a 4-6 inch on the ski i wouldnt stud it unless you get longer ones or youll push bad in the corners.
96 Formula III 600 Triple
86 Pantera 440, ladies
RoloCade is offline   Reply With Quote
