Old 02-01-2005, 06:16 PM   #1 (permalink)
Arctic
Arctic's Avatar
Exclamation Hood Cracks....How to fix them???
Is there any cheap way to fix hood cracks? Is there any particular kind of snowmobile hood that won't crack easily?
Arctic is offline   Reply With Quote
Old 02-01-2005, 06:27 PM   #2 (permalink)
skidoo_magoo
Go Wings!
skidoo_magoo's Avatar
well, there's always snowmobile stitches as i call them. just take zipties and stitch the crack shut like that, or what i did for my 500 was bought this plastic bond/sealent for anything plastic and used it.
then, my dad got really creative and cut off some plastic from our pool filter flap to replace the plastic that the bracket hooks up to and used a plastic repair kit to mend it to the hood.
i have heard of people switching hoods from different years or aftermarket companies, but dont know which company. and i think the lexan ones dont crack as easy, but they are big bucks. anyone know about different hoods and how well they resist cracking?
Old 02-01-2005, 08:12 PM   #3 (permalink)
1sickcivic
1sickcivic's Avatar
GO buy a fiberglass repair kit from wal -mart meijers etc.it will cost you like 11.00.depending on how pateint you are you will get it perfect.that what i repair hoods with.I use to repair boat damge for a shop.what they need to make if urethane hoods.they will never crack or brake.i have urathane bodykit on my car and hit a tire doing 75 never broke just chipped the paint.
1sickcivic is offline   Reply With Quote
Old 02-03-2005, 11:16 AM   #4 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
http://www.brtechracing.com/
I dont know if they have head light openings.
http://www.hiperf.com/
Old 02-04-2005, 04:35 PM   #5 (permalink)
SnowRida
Runnin Against The Wind!
SnowRida's Avatar
That's what I did in the past. If you get enough of them, it tends to look kind of radical. Or like Gerry Cheevers goalie mask.
SnowRida
Yamaha V-Max
02 MXZ 600
97 Polaris Indy Trail Touring
Old 02-05-2005, 10:03 PM   #6 (permalink)
Redneck Ron
Senior Junk Collector
Redneck Ron's Avatar
Oh god...Yes they look okay for a repair but one of my friends has a three wheeler someone went overboard and started drilling holes and putting the "snowmobile stiches" on where there were no cracks at all.lol
Ron
1997 Polaris XCF 440 Fan
2002 Honda TRX400EX
1977 Firebird Formula
1971 Camaro
1967 Mustang
~"Rollin on Hubz"~
Redneck Ron is offline   Reply With Quote
Old 02-12-2005, 11:35 AM   #7 (permalink)
BLinindoll
just in case it cracks where he put the extra stiches he wont have to stich it up.... its already done....
~S.O.T.M. January 2006~
98' Cat ZR600 EFI Limited Edition
-Black Magic Clutch
-Black Magic HotRod Chip
-Boyesen power reeds
-Unknown Silencer
-Ripsaw track w/144 Woodys
-Geared 1 down, 1 up
-3.5" Ole's angled riser
BLinindoll is offline   Reply With Quote
Old 02-12-2005, 11:53 AM   #8 (permalink)
skidoo_magoo
Go Wings!
i've seen people with 'em all the way up their hood! that's when you just get a new one...
Old 02-13-2005, 11:39 PM   #9 (permalink)
600SE
600SE's Avatar
Re: Hood Cracks....How to fix them???
1st Q-I don't know
2nd Q-2 inch thick steel hoods never crack, even when you pound on em with a hammer, makes the sled go kinda slow though
-85 Indy trail
-85 Indy 600SE
-89 Indy 650
-68 Super olyimpic
600SE is offline   Reply With Quote
Old 02-14-2005, 06:31 AM   #10 (permalink)
IndianRvrShiver
IndianRvrShiver's Avatar
sickcivic is on the right track..........get a fiberglass repair kit that includes resin with hardener, & fiberglass mat/cloth. Work from the underside of the hood. Rough up the area around the crack with 60 grit sandpaper; apply some resin with a cheap paintbrush, lay in some mat/cloth (make sure you apply more resin so the mat/cloth is saturated). Repeat so you have about 3-4 layers for added strength.
Should be plenty strong & you won't even need to mess up the paint/decals on the top side.
Old 03-14-2005, 07:18 PM   #11 (permalink)
ITriumph
F.K.A. MOUSE72
ITriumph's Avatar
There's also some stuff called "tigers hair" I don't know who makes it. It's supposed to be better than fibreglass. I'm sure any auto parts store will carry it.
snow and ice imagery
extended forecast for Alanson
And on the eighth day, god created snowmobiles .
ITriumph is offline   Reply With Quote
Old 03-23-2005, 06:54 PM   #12 (permalink)
01MXZ800
01MXZ800's Avatar
all tiger hair is is bondo with fiberglas strands mixed in all that is used for is base coat on patches and rust holes. like mentioned above use cloth and resin on backside and if needed use light weight filler on good side if you have to repaint hood make sure that you do a good job sanding the hood with 220 grit(for primer)
and 320-400 grit for finalcoat i have not had any problems painting hoods no matter what they are made of as long as the sanding and prep work is done properly hope this helps. good luck!!
01 MXZ 800 (his)
96 XCR 600 (hers)
Lake Shore Snow devils Snowmobile Club
Old 03-24-2005, 07:04 AM   #13 (permalink)
gman250
gman250's Avatar
I agree with civic. Our old 1978 Yamaha 250 has seen a few trees in it's past. Did a big fiberglass repair and paint this summer and it worked great. Cheap and effective.
04 F7
00 Magnum 500 ATV
78 Yamaha 250ET
http://community.webshots.com/user/gman250_500
gman250 is offline   Reply With Quote
Old 08-05-2005, 07:53 PM   #14 (permalink)
jlautoworks
Yes there is, you can mechanically weld this type of plastic. Pre 98 machines use a fiberglass kit. No more stitches or glue. Alot of parts can be repaired so its undetectable without having to repaint. See http://www.jlautoworks.com
jlautoworks is offline   Reply With Quote
