Zip-ties vs. Plastic welding - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 15 (permalink) Old 01-10-2010, 08:40 PM Thread Starter
just mEEEEE
Gunther47's Avatar
which is stronger?
-straight zip ties?
-crissCrossed zip ties?
-thermal plastic welding?
i already know from lots of experience the crissCrossed zip ties look the best
2000 MXZ 600
2003 Grand Touring 380f
89 Safari 377
Gunther47 is offline
post #2 of 15 (permalink) Old 01-10-2010, 08:43 PM
Rick
indyryder500's Avatar
how you weld plastic?
indyryder500 is offline
post #3 of 15 (permalink) Old 01-10-2010, 08:51 PM Thread Starter
just mEEEEE
Gunther47's Avatar
you use a plastic welder tool, either thermal or ultrasound, to bond two pieces of plastic together. i just welded my windshield because a windshield doesn't look good with zip ties. but i was wondering if i should weld or zip tie the cowl im looking for strength here
2000 MXZ 600
89 Safari 377
post #4 of 15 (permalink) Old 01-10-2010, 08:54 PM
Rough up the back side of it and use some fiberglass cloth/resin.
2009 Ski Doo MXZ 500SS TnT
1999 Ski Doo MXZ600
smallengineguy is offline
post #5 of 15 (permalink) Old 01-10-2010, 08:59 PM Thread Starter
just mEEEEE
Gunther47's Avatar
how do you do this fiberglass cloth method, and is it the strongest?
2000 MXZ 600
89 Safari 377
post #6 of 15 (permalink) Old 01-10-2010, 09:00 PM
One way to plastic weld is to use a soldering iron. You melt the plastic on both sides of the crack and mix back in to it's self. If done right it looks like a scratch. I did it to my belly pan on a 01 polaris xc 800 and it seams to be holding up very well and I ride it hard. Hope it helps but it does take a while.
ChrisB is offline
post #7 of 15 (permalink) Old 01-10-2010, 09:27 PM Thread Starter
just mEEEEE
Gunther47's Avatar
yeah, a soldering iron is as good as a high-tech welder. and the smaller the tip, the prettier. so, im not gonna have an
░▀▀▀ ░▀ ░░░▀ ░▀▀▀ ░░▀ ░░░▀░▀ ░▀ ░▀▀▀ if i do my cowl in weld? and i guess i could do the belly pan too, cause it is cracked with a skid plate over it cause the previous owner didn't care too much
2000 MXZ 600
89 Safari 377
post #8 of 15 (permalink) Old 01-10-2010, 09:42 PM
I would try on a small spot on the inside first just to see, but its worth a try. And I put a skid plate on ofter I welded the belly pan for extra support. But even after hitting a big rock dead center hard while braking a trail it still didn't recrack. good luck.
ChrisB is offline
post #9 of 15 (permalink) Old 01-10-2010, 09:51 PM Thread Starter
just mEEEEE
Gunther47's Avatar
did you weld from both sides? or just the inside? i weld both, to make sure its bonded, is that necesary? or can i get a good weld from one side, and save te ugly look?
2000 MXZ 600
89 Safari 377
post #10 of 15 (permalink) Old 01-10-2010, 10:03 PM
I did on both sides just to make sure it would hold. Go about half way threw each side to make sure its mixed together well. My brother showed me after he did it on his sports bike. It works well. And the looks like a small scratch unless you get real close.
ChrisB is offline
post #11 of 15 (permalink) Old 01-17-2010, 09:51 PM
2005 XCSP500
RedRocketSled's Avatar
Plastic weld it for sure ive done it to a few sleds and it works great
RedRocketSled is offline
post #12 of 15 (permalink) Old 01-24-2010, 07:18 PM
Polarisftw123's Avatar
What about plastic welding a Cobra flared windshield? last year i hit a drift and cracked it almost in half
Polarisftw123 is offline
post #13 of 15 (permalink) Old 01-25-2010, 05:52 AM
2005 XCSP500
no
sorry but no the cobra windshields are made of polycarbonate and if you try to plastic weld it it will just become very brittle and probably break more. you could do to things new windshield or the zip tie scar way in an X shape works good
Well seing as somone stole my xcsp now i own a 2011 switchback 136" with polaris hand-guards 162 studs woodies dually carbides and a tunnel bag
soon to come; exhaust, port & polish, clutching and gearing
Stolen
2005 Polaris XCSP 500
Mods:
Red lexan hood(see through), 1.5" pivot riser+ 2.5" that i CNCed, extended brake and throttle, sport teck hand guards, red chrome cobra windshield,1.25" ripsaw with 120 studs,and boysen power reeds.
Stolen form glen morris ontario, canada
post #14 of 15 (permalink) Old 01-26-2010, 05:38 AM
They make fiberglass repair kits you can buy. Comes with everything you need and are the strongest IMO.
1999 Ski Doo MXZ600
post #15 of 15 (permalink) Old 01-30-2010, 01:15 AM
I have used a plastic bumper repair epoxy. When you mix it, it is black in color and flexible and sandable. Available at O'reilly Auto parts and others. Works great. I have repaired hoods with it. I have not had a repair come apart, but there is always a first time.
iride4fun is offline
