yes there is.. you might be able to tie into a live wire , and hook it to ur positive post, and ground the other side. I put my cheetah engine into my dunebuggy, with electric start, and had a wiring harness out of a different sled, and managed to get it all right, chopping and mending wires for the electric start, everything works, even lights!! but the lights work off of the stator, not the battery. hooking up extra lights may not benefit, because amperage is split up, giving less power to everything else.. hope this helps!~!!
