Old 08-29-2008, 12:26 PM   #1 (permalink)
heiner921
LED Lights on a 2001 Ski-doo MXZ 700
Hi there i want to put some LED lights under the running boards on my 2001 Ski-doo MXZ 700. I dont want to spend alot on them. I'm looking at like $20 Maximum. I was wondering if these would work. This is the link to them.
20x Yellow LED Lamp Light Set 25cm Pre Wired 5mm 12V DC - eBay (item 250287994043 end time Aug-31-08 00:02:21 PDT)
Or
Car Auto Van Wheel Strip LED Bulb Light 48cm 12V Yellow - eBay (item 170255628290 end time Aug-29-08 15:32:24 PDT)
I plan to wire them all together and the use a toggle switch to turn them on and off then wire them into the headlights. Will this plan i have work or should i do it differently?
heiner921 is offline   Reply With Quote
Old 08-29-2008, 01:01 PM   #2 (permalink)
heiner921
I also just found this that i think will work good for me.
20-LED Accent Light Kit Wiring Harness - ANY COLOR [20 Kit Single Color Harness] - $26.79 : Led Accent Lights, Specializing in Motorcycle LED Accent Lights
Old 08-30-2008, 01:32 PM   #3 (permalink)
JheLrey
JheLrey's Avatar
If you are going to do LEDs on a snowmobile, you will need a resistor or you will blow all of the LEDs.
JheLrey is online now   Reply With Quote
Old 08-30-2008, 01:59 PM   #4 (permalink)
heiner921
these LEDs have them already with them in the kit. Also there are fuses.
Old 08-30-2008, 03:59 PM   #5 (permalink)
skidoorider
skidoorider's Avatar
i had the same leds as the ones in the first link you posted except mine were red. i think wiring them to the headlight will work just fine. this is what i did with mine.
its a lot brighter in real life and at night they were really bright.
08 ski-doo mxz adrenaline 800r
04 ski-doo mxzx 800ho
97 polaris xc 600 triple
87 ski-doo safari 377
skidoorider is online now   Reply With Quote
Old 08-31-2008, 06:22 AM   #6 (permalink)
heiner921
Sounds Sweet
Old 08-31-2008, 03:59 PM   #7 (permalink)
JheLrey
JheLrey's Avatar
Try Snowglow... Just heard of it the other night...
Old 09-01-2008, 06:29 AM   #8 (permalink)
heiner921
they are as little pricey for my budget these days
Old 09-01-2008, 06:39 AM   #9 (permalink)
lowbudget
Mountain Man
lowbudget's Avatar
Here they are on "special".Specials : Led Accent Lights, Specializing in Motorcycle LED Accent Lights This will teach me to be bored at work as I ended up ordering a set for my Summit.
lowbudget is online now   Reply With Quote
