» Site Navigation
» Power Sports Links
Old 02-06-2008, 06:59 PM   #1 (permalink)
Iowa Ditch Banger
polarisman5's Avatar
Handle Bar Risers
My 3 inchers didn't fit on my sled, 1999 Polaris Indy 500 RMK
Cables were too tight, but yet I see other people on here with Polaris' that say their 3 inch risers fit! Any suggestions?
-1999 Polaris Indy 500 RMK-
polarisman5 is offline   Reply With Quote
Old 02-06-2008, 07:01 PM   #2 (permalink)
2nd Assistant Highjacker
Ditch hopper's Avatar
try re routing your cables that might give you the extra room or get throttle and break extensions!
Real men Hijack threads
-1995 zr580- aaen pipe, epi clutch kit, camoplast ripsaw/120studs, 3inch riser, flybars, upgraded foxshocks, weisco pistons, lightly ported, 19tooth top 32thooth bottom soon to come bored carbs, plastic skis, new helix and ramps BRAAAP
Ditch hopper is offline   Reply With Quote
Old 02-06-2008, 07:13 PM   #3 (permalink)
Iowa Ditch Banger
Ditch Hopper, extensions cost money. I'm in college and can't afford that! I'll look to re route I suppose or bandsaw off 1/2 an inch
Old 02-06-2008, 07:15 PM   #4 (permalink)
lmao you need about an etrax inch of cable for turing im sry to say but moding is pricy
Old 02-06-2008, 07:22 PM   #5 (permalink)
Iowa Ditch Banger
I know I know, but cutting it is free, so thats the way its going to happen if I can't get it to work by re routing the wires. Clutch kit would be nice too, but thats more money.
Old 02-06-2008, 07:25 PM   #6 (permalink)
id say save your money till you can afford them dont hack the riser no point in doing a hack job imo
Old 02-07-2008, 10:29 PM   #7 (permalink)
ENR_Kyle20's Avatar
yea I dono. I got mine to work fine. I have some aftermarket cables from dennis kirk. I bougt them way before I decided to get risers so I just got what they says was stock size. But for me. it worked great until i turned right. it would give one cylinder more gas when I was turning. so what I did was cut a small notch in my hood so it can pull down a little more (the cable goes in the notch when I close the hood).. that fixed it. works great now. did you try swaping the cables left to right. the left carb is offset and takes a little longer cable. Mine were originally backwords - It would not work unless I swaped them.
If you REALLY wanted to use the full three inches you could rout the cables THREW the air box. I think i would cut off a 1/2 an inch before that.
is it just throttle or brake cables to?.. All I did for the brake cable was bend the metal portion of the line up a litle and it worked great!
1996 Polaris Indy 500 SKS
Fresh Rebuild 12/1/07
Parts Unlimited Pistons/Rings
Bored 30/1000's
Shaved Head
3" Bar Riser
2,200 Miles
(Dont Forget To Grease Your JackShaft Regularly)
ENR_Kyle20 is offline   Reply With Quote
Old 02-08-2008, 12:02 PM   #8 (permalink)
Iowa Ditch Banger
I'm too snowmobile illiterate to know which cables they are that are too tight, but come next Wednesday, I'll have those risers on one way or another!
Old 02-08-2008, 12:48 PM   #9 (permalink)
ENR_Kyle20's Avatar
ahh, if you cant tell a throttle cable from a brake line I dont think you should be working on a snowmobile. not to be mean. lol.. but the throttle cable goes directly into the carb and it a plastic like cable that come from the right side of the bar. the brake line is rubber and goes directly to the brake and comes from the left side of the bar.
Bored 30/1000's
Shaved Head
3" Bar Riser
2,200 Miles
Old 02-08-2008, 01:56 PM   #10 (permalink)
spanky follow the lines going from the break handle to the caliper! and the line coming from the throttle to the carbs
Old 02-08-2008, 05:15 PM   #11 (permalink)
Iowa Ditch Banger
I've hardly even looked at it ya dicks! I'm sure if I take the time and looked I could easily figure it out. Not to mention I'm always 50+ miles away from my snowmobile, no room to park it at my apartment...
Old 02-08-2008, 05:17 PM   #12 (permalink)
No one likes a lier do you kno what a spark plug is?
Old 02-08-2008, 05:26 PM   #13 (permalink)
Iowa Ditch Banger
Yeah, I changed those before I put hardly any miles on this year. Needed fresh blood in there, made sure she was runnin' tip top!
Old 02-08-2008, 09:36 PM   #14 (permalink)
Chasing the white wolf!
chopper's Avatar
Lol
chopper is offline   Reply With Quote
Old 02-08-2008, 09:42 PM   #15 (permalink)
Lol
Old 12-11-2008, 01:27 PM   #16 (permalink)
I put on a 3 inch ply pivot riser and a pivot adapter for a total rise of about 4 1/2 inches, and didnt have to lengthen cables at all. Should be pretty basic.
polarisguy218 is offline   Reply With Quote
