Old 03-05-2007, 07:43 AM   #1 (permalink)
MXZ670Rider
MXZ670Rider's Avatar
riser
i just ordered and 5'' handlebar riser for my 99 mxz 670 and i was wondering if i have to extend the brake and throttle cable. let me no thanks.
It's a downright joy for a country boy
when he hears them engines moan .
'02 Arctic Cat ZR800 bored to a 1010cc Psi pipes, vforce reeds, clutched, works suspension.
'96 Arctic Cat Wild cat 700 efi
'77 Arctic Cat Pantera (reconditioning it)
'01 Yamaha blaster 200 with custom exhaust
'06 Arctic Cat 650 Twin
Wheel horse garden tractor w/ 10hp kohler. does 35mph ,2 seats, stereo, wheelies.
racing lawnmower 18hp kohler bored +.025 over, racing cams,egged head. 60mph
MXZ670Rider is offline   Reply With Quote
Old 03-05-2007, 07:29 PM   #2 (permalink)
pjabas
pjabas's Avatar
its hard to say, install it then with the motor OFF turn bars lock to lock and check for free play in cables and wires,
pjabas is offline   Reply With Quote
Old 03-05-2007, 08:54 PM   #3 (permalink)
MXZ670Rider
i planned on that i just was wondering if ne one knew so i could the extension with the riser. thanks
Old 03-05-2007, 09:05 PM   #4 (permalink)
mmrosshere
Wants to see snow
mmrosshere's Avatar
I also would like to see you take the belt off when you first start it and turn the bars to make sure it does not launch when the cables get pulled.
84 srv 540 starting to mod
98 indy classic xlt 600
LET ME OUT OF THE HOUSE
Old 03-05-2007, 09:20 PM   #5 (permalink)
MXZ670Rider
yea i m not gunna lie t ya i didnt think of that. but it is a really good and safe idea thanks
Old 03-06-2007, 09:33 AM   #6 (permalink)
dobbs
www.315er.net
dobbs's Avatar
i got 4 1/2" out of my 97 MXZ, i cut the zip ties that held the cables and changed the angle the break line went into the caliper.
Make sure after you get it installed you start it up on a stand and turn the bars all the way to the right and left to make sure it doesn't pull your throttle cable. Also check that it doesn't pull the cable that goes to your oil pump. I had a buddy that put a riser on and wondered why he suddenly was going through a tank of oil w/ every tank of gas.
dobbs is offline   Reply With Quote
Old 03-08-2007, 06:00 PM   #7 (permalink)
G.T
G.T's Avatar
sorry to bring bad news but most of the cables will need altering. I tryed to fit just a 2" riser and came into a few problems although it would have worked just i dont like cutting corners.. .
G.T is offline   Reply With Quote
Old 03-09-2007, 09:55 AM   #8 (permalink)
dobbs
www.315er.net
dobbs's Avatar
what do you consider cutting corners?
Old 03-09-2007, 11:36 AM   #9 (permalink)
G.T
G.T's Avatar
Not extending the throttle cable for a start! Not a hard job just a little work involved. I encountered problems just with a 2" riser
Old 03-09-2007, 11:46 AM   #10 (permalink)
dobbs
www.315er.net
dobbs's Avatar
well, i encountered zero problems with almost 5", what machine did you do this on?
Old 03-09-2007, 12:39 PM   #11 (permalink)
G.T
G.T's Avatar
My wifes 99 670 H/O
Old 03-10-2007, 08:31 PM   #12 (permalink)
SkiDooFormulaMX
GO GREEN OR GO HOME!
SkiDooFormulaMX's Avatar
i just did 2 inches on an 87 formula last night with no problems at all on the run today.
2003 ARCTIC CAT ZL 600 EFI SS-2700 MILES-GETTING SOME MILD TWEAKING THIS SUMMER
1997 ARCTIC CAT EXT 580 EFI-4000 MILES-GETTING SOME SICK TWISTED MODS THIS SUMMER
2002 ARCTIC CAT Z 440 ES-622 MILES-MINT, JUST LOOKING FOR SOME STUDS AND FATBOY TORSIONS.
1998 ARCTIC CAT ZR 600 EFI-3700 MILES-BUILT-SOLD-9/07
1996 INDY CLASSIC 500 ESR-5100 MILES-SOLD 4/08
1987 SKI DOO FORMULA MX 470-12000 MILES-SOLD 12/07
SkiDooFormulaMX is offline   Reply With Quote
Old 03-11-2007, 09:55 PM   #13 (permalink)
MXZ670Rider
i put it on and had to clip the zip ties holdin the brake line in place and then she workd out fine, i just couldnt tip the bars up as far as i wanted but its all good it is only about 1/4 in to low but i still like it.
Old 03-12-2007, 08:35 PM   #14 (permalink)
Formula_Canuk
Back Out!
Formula_Canuk's Avatar
I put 3 1/2" on my poo and didn't even have to cut any ties.
96' Formula III 600 triple
02' XCSP 800 edge
Formula_Canuk is offline   Reply With Quote
Old 04-20-2007, 07:47 PM   #15 (permalink)
skidoo kid 102
sundaypuncher 503
skidoo kid 102's Avatar
i have 97 mxz 670 and i put 5in? risers and handlebars on mine, i did have to buy a throttle ext. kit, but i held off on buying a longer brake line. i just re-routed thr brake line and moved the brake lever closer to the center of the bars. works fine! saved $50+
THE BEST THINGS IN LIFE GO BRAAAAAP!!!!!!
skidoo kid 102 is offline   Reply With Quote
Old 08-03-2007, 12:23 PM   #16 (permalink)
idooski
idooski's Avatar
Most times you can get away with at least a 4" riser with no alterations other than some re-routing. I have sold many up to 6" that required no alterations, but there are some shorter than 4" that needed cable extensions or other alterations. You really need to be very careful to check all of your cables, wiring and brake lines closely for interference or binding. It's just not worth taking the chance of meeting a tree under the wrong circumstances.
idooski is offline   Reply With Quote
Old 08-13-2007, 06:07 PM   #17 (permalink)
dryice000
i put a 6 inch on mine and all i had to do was extended the throttle cable (was only like 2 inch's short and i had to ad a 10 inch extension so now the cable is way to long) and had to change the angle of the brake line on the leaver.
dryice000 is offline   Reply With Quote
Old 08-13-2007, 11:54 PM   #18 (permalink)
PolarisINDY500
SENIOR MEMBER
PolarisINDY500's Avatar
what you can do is cut a piece of wood to the size of your riser before you buy it. then you can test fit it to see if you'll need new cables.
i put on a 2" riser on my sled, and that is the highest i can go before needing to extend the cables.
but remember, if you have hand warmers or any other cables they may need to be extended as well. not just the throttle/break.
The Original Logo ->
GALLERY UPDATED with 2007 Photos
SF.com 3rd Annual Michigan Ride: FEB '08: Presidents Weekend
Old 09-30-2007, 04:37 PM   #19 (permalink)
RedRider_AK
Know-it-all hooligan
This is sorta related to this post, do they sell throttle cable and brake line extensions? I am putting some 5 or 6 inch risers on my ZR500 this winter, along with some Tag bars and other stuff, and am probably going to need to extensions. How expensive are these parts? Thanks for the help.
RedRider_AK is offline   Reply With Quote
Old 09-30-2007, 08:58 PM   #20 (permalink)
Formula_Canuk
Back Out!
They sell the extensions. Your looking at about $85 for the throttle and brake extensions. Click the link and go to page 240 Royal Distributing - Snowmobile Parts and Accessories. ATV, Motorcycle Parts and Accessories. - Catalogue - Snowmobile
02' XCSP 800 edge
