» Site Navigation
» Power Sports Links
Old 01-25-2007, 06:05 PM   #1 (permalink)
exhaust painting help
Hello was wondering how to prep an exhaust for painting I don't have a sand blaster or a paint gun so I will be using a spray paint. Also the exhaust is out of a 1990. thanks
matthew_1978 is offline   Reply With Quote
Old 01-25-2007, 08:16 PM   #2 (permalink)
Wants to see snow
mmrosshere's Avatar
Wire brush clean. Or You could get fancy and sand it all down. None the less spray it then when the rust starts to show spray it again. One can could do the whole thing several times.
84 srv 540 starting to mod
98 indy classic xlt 600
LET ME OUT OF THE HOUSE
Old 01-25-2007, 08:21 PM   #3 (permalink)
m_440z_daddy's Avatar
make sure you use high temp paint BBQ black works best..
m_440z_daddy is offline   Reply With Quote
Old 01-25-2007, 08:33 PM   #4 (permalink)
jagermiester's Avatar
I have painted a couple and the best spray bomb I found was the ceramic based stuff. Seems to stick better w/ the high heat. Doesn't flake off. Not powdery either.
98 Jag (for the kids)
03 MXZ-X 800 (Blair Morgan)
Old 01-25-2007, 09:09 PM   #5 (permalink)
Wants to see snow
mmrosshere's Avatar
What is the brand?
Old 01-25-2007, 09:18 PM   #6 (permalink)
VHT
Flame Proof Header Paint
Ceramic Coating
Painted this one 3 years ago
Good stuff
Old 01-25-2007, 10:18 PM   #7 (permalink)
Wants to see snow
mmrosshere's Avatar
I'll have to look for that.
Old 01-26-2007, 06:11 AM   #8 (permalink)
can I use a wire brush on a drill I guess that would be a wire wheel also what grit of sand paper should I use
thanks
Old 01-26-2007, 07:10 AM   #9 (permalink)
I used a wire brush on an electric die grinder. Don't use too much pressure tho, if you have any rusty or week spots you will burn thru.
Old 01-27-2007, 10:41 PM   #10 (permalink)
Head horsepower junkie
SSnthe10s's Avatar
i used duplicolor 1500 degree paint. It holds up great. also how come nobody paints their header pipe. it looks like crap when poeple dont! just my pet peev.
1995 Indy RXL modded....-Sold
SSnthe10s is offline   Reply With Quote
Old 01-30-2007, 12:29 PM   #11 (permalink)
headbanger7483's Avatar
Here's what I do.
1. Wirebrush to get all the loose rust off
2. Paint with a Naval Jelly (neutralizers rusts and makes a good primer)
3. Paint with a very high heat paint
I BLEED GREEN
2002 ARCTIC CAT ZR 500
1999 ARCTIC CAT ZL 500efi
1993 SKI DOO MACH 1
headbanger7483 is offline   Reply With Quote
