Old 12-21-2006, 09:44 PM   #1 (permalink)
polarisindy
polarisindy's Avatar
Riser?
I'm a rather tall 6'4 and when I stand to ride I have to bend over a decent amount to grab the bars. I was looking into getting bar risers. I was thinkin 4", for this I think i'll need a throttle extension too. Are those hard to put in? Does having a triple make it any different? What about brake extensions too?
1997 Polaris Ultra SPX 680
-Triple LRM Pipes, Delta V-Force Reeds, Ported, Heads, Hot Seat Clutch Kit, Camoplast Ice Claw Track
Yea........its fast!!
Polaris Hands Down!!
polarisindy is offline   Reply With Quote
Old 12-22-2006, 01:27 AM   #2 (permalink)
Use a block of wood cut to the size you want as a dummy and test it first.
Vote for me in the Nov. SOTM.
I will shamelessly promote myself all over the forum.
Old 12-22-2006, 09:12 AM   #3 (permalink)
RMK 600
RMK 600's Avatar
most polaris's can only fit a 2.5" riser without cable extension's. throttle cable is easy and so is the brake but you will have to bleed your brakes after putting on the new cable and filling up the resevoir. If you only wanna go 4" try and reroute the cables to get enough length because riser blocks are cheap it's the cables that get pricy. don't forget about all the wiring as well. On a sled like your's to make a decent stand up position you need at least a 6" riser and probably a pivot block so it goes up not back towards you.
2006 600 RMK
YOU SHOULDN'T CRITICIZE SOMEONE UNTIL YOU HAVE WALKED A MILE IN THEIR SHOES; THAT WAY YOU ARE A MILE AWAY AND YOU HAVE THEIR SHOES!
RMK 600 is offline   Reply With Quote
Old 12-22-2006, 10:47 PM   #4 (permalink)
rgoers
rgoers's Avatar
BE SURE about whether or not you NEED a cable extension.
Had a friend tell me about his buddy who wrecked his sled a couple weekends ago. Just put the riser on it - out for his first ride... "Thought" the cable length was okay, until he made a hard right. Ended up driving right into a tree at full throttle.
2000 440 Panther
1980 Jag 3000 F/C
