Old 08-30-2005, 07:04 AM   #1 (permalink)
dhodder
Question 2002 440 Panther Track
I have a 2002 440 acrtic cat panther which currently has a 15 x 136 x .75 track. I'm wondering if I can go with a larger lug such as 1.25 or 1.5 without causing me any trouble?
Thanks alot
Doug
Mount Pearl, NL
dhodder is offline   Reply With Quote
Old 08-30-2005, 11:52 AM   #2 (permalink)
SledStormIanAmy
Water Runner
SledStormIanAmy's Avatar
You might get away with a 1.25" lug, but you definitely need to go with smaller driver if you are going to go for a 1.5" lug. That can do damage to your tunnel (Worse if it is studded.) To check for tunnel clearance, compress the rear suspension with the track on, then measure the didstance between the tip of the lug and the end of the tunnel closest to the drivers (Drive Sfaft.) the Minimum amount of distance needed is three-quarter of a inch.
!997 Polaris Storm 800
3" Riser
Handlebar Hooks
1.5" Lug Track
SledStormIanAmy is offline   Reply With Quote
Old 09-04-2005, 08:31 PM   #3 (permalink)
rgoers
rgoers's Avatar
I put a 1.25 on my 2000 Panther 440 last season. Didn't have a problem with clearance at all. It did seem to lose some top end though.
2000 440 Panther
1980 Jag 3000 F/C
