Old 08-27-2005, 10:12 AM   #1 (permalink)
rgoers
rgoers's Avatar
Starter Rebuild
Anyone ever rebuild a starter? Mine quit working (2000 ZL550) last winter. Thought it was a battery, but tried bypassing the solenoid with a jumper, and no-workie.
Seems to be free-turning, so I assume it's just brushes.
Any tips (besides "take it to a professional")?
2000 440 Panther
1980 Jag 3000 F/C
Old 08-27-2005, 01:00 PM   #2 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
starter are not hard to take apart, there will be about 6 pices to the whole thing.
http://www.hiperf.com/
Old 08-27-2005, 07:56 PM   #3 (permalink)
Welcome back! You'll need to replace the bottom end "stuff" (brushes, springs, bearing). They usually make a kit for it.
Old 08-27-2005, 11:06 PM   #4 (permalink)
rgoers
rgoers's Avatar
Thanks SEG. It's been a busy summer!!! Kids have worn me ragged. Can't wait for the snow, so I can go out and relax.
I saw an Arctic Cat kit on eBay for $26. Sound about right?
BTW - I might be able to catch up on repairs if I didn't have to spend the PM in the emergency room. I was running some CAT5 wire downstairs, and stood up too quickly underneath my furnace chimney pipe. Put a 2 inch gash in my head. Got 4 stitches out of the deal, and a few hour setback on my project...
2000 440 Panther
1980 Jag 3000 F/C
Old 08-28-2005, 06:42 AM   #5 (permalink)
Now you're all set. Every project I work on, I get a cut somewhere. But I've determined once I get one, that's it for getting wounded on that project. So you shouldn't get any more wounds on the CAT5 thing.....$26 sounds about right for the kit.
Old 08-28-2005, 01:42 PM   #6 (permalink)
rgoers
rgoers's Avatar
Great... $26.
I did finish the project when I got home. Didn't get hurt again either. I think there's something to your theory.
2000 440 Panther
1980 Jag 3000 F/C
Old 09-05-2005, 10:53 PM   #7 (permalink)
rgoers
rgoers's Avatar
Got the starter pulled apart. Brushes were shot - some brush wires were broken.
The only thing I'm concerned about is the front shaft looks worn pretty bad. I would have to replace the whole armature assembly. Browns lists it for $152 (CAN). Ouch!
I'm thinking that since the starter doesn't run much, maybe I can get away with the worn shaft?
2000 440 Panther
1980 Jag 3000 F/C
Old 09-06-2005, 07:24 AM   #8 (permalink)
It shouldn't matter too much, just get a good lube to put on that shaft. If you were going to use it a lot, I'd say replace it.
Old 09-06-2005, 06:55 PM   #9 (permalink)
rgoers
rgoers's Avatar
Sounds good to me...
2000 440 Panther
1980 Jag 3000 F/C
