Old 06-21-2005, 03:06 PM   #1 (permalink)
Dusty Ganey
info needed! 1996 ZRT 800
looking for info on the front end set up of a 1996 ZRT 800. My friend owns this sled and wants to know if the cam arm can be removed from the linkage bar, rotated down, and replaced to lower the suspension arms which would raise the front of the sled? I probably do not have the part name terminollogy correct. My photo was too large for the forum, so I could not include it.
THANKS
DUSTY
Dusty Ganey is offline   Reply With Quote
Old 06-21-2005, 03:58 PM   #2 (permalink)
ITriumph
F.K.A. MOUSE72
ITriumph's Avatar
You can resize you r photo. 600x600 is the biggest you can put on here. As for the other item I have no idea. Not familiar with AC.
By the way, welcome to the forum.
snow and ice imagery
extended forecast for Alanson
And on the eighth day, god created snowmobiles .
ITriumph is offline   Reply With Quote
Old 06-21-2005, 04:21 PM   #3 (permalink)
Dusty Ganey
THANKS FOR THE INFO. I WILL TRY TO RESIZE IT.--NO LUCK.
DUSTY
Old 06-21-2005, 09:49 PM   #4 (permalink)
ITriumph
F.K.A. MOUSE72
ITriumph's Avatar
If you need a hand just let me know. I would be more than happy to help out. Did you get my PM?
Old 06-22-2005, 06:24 AM   #5 (permalink)
SnowRida
Runnin Against The Wind!
SnowRida's Avatar
Hey Dusty, where are you in MI.?
SnowRida
Yamaha V-Max
02 MXZ 600
97 Polaris Indy Trail Touring
Old 06-22-2005, 11:53 AM   #6 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
if you are talking about the sway bar just take it off, they dont do anything.
http://www.hiperf.com/
Old 06-22-2005, 09:57 PM   #7 (permalink)
Dusty Ganey
to SnowRida
I am in Clinton Township. The sled is in Berkley.
Dusty
Old 06-22-2005, 10:01 PM   #8 (permalink)
Dusty Ganey
Reply to Sesnopro
I believe it is part of the sway bar assembly, but my buddy is wondering if it will lift the front suspension if he removes the cam/arm , rotates it down, and replaces it.
Dusty
Old 06-22-2005, 10:33 PM   #9 (permalink)
ITriumph
F.K.A. MOUSE72
ITriumph's Avatar
Re: to SnowRida
Dusty
The company I work for is based in Warren.
Old 06-25-2005, 02:03 PM   #10 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
it wont raise it any, thw most it will do is buck you off, taking off the sway bar is usualy the first thing people do with a conventional chasis like the zrt or zr.
Old 07-05-2005, 03:18 PM   #11 (permalink)
Dusty Ganey
HERE IS A PHOTO.
Old 07-09-2005, 10:25 AM   #12 (permalink)
ITriumph
F.K.A. MOUSE72
ITriumph's Avatar
that looks to be part of the sway bar assy. I'm not familiar with AC, so I can't tell you to just remove it. From the looks of you pic, it doesn't look like it does anything. I found this link for you. It has the parts diagram for your sled. I hope this will help
http://www.alpha-sports.com/Parts/1996Snow.htm
Old 07-09-2005, 12:10 PM   #13 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
remove, a zrt is a drag sled, keep it low.
Old 07-15-2005, 03:04 PM   #14 (permalink)
Dusty Ganey
MOUSE 72, SESNOPRO--THANKS
THANKS FOR THE INFO. IT IS VERY HELPFUL.
DUSTY
Old 07-15-2005, 06:47 PM   #15 (permalink)
ITriumph
F.K.A. MOUSE72
ITriumph's Avatar
no problemo man. anytime
Old 09-13-2005, 11:53 PM   #16 (permalink)
jtman04401
800cc + or go home
jtman04401's Avatar
If you plan on trail riding this sled DO NOT REMOVE IT ! Unless you want allot of inside ski lift and sway in your front. This bar connects the left and right side much like a coupled rear suspention does front to rear. If you remove it on a hard corner the side with the most weight (outside ski) will sag too much and create inside ski lift!! You do not want this !!!!
"Freedom is too precious to be held by the LEFT hand."
jtman04401 is offline   Reply With Quote
