Old 04-04-2005, 09:58 PM   #1 (permalink)
hanksled
hanksled's Avatar
Suspension bolts
any good ideas on removing the bolts that hold the bogie wheels? I am talk about the ones that share the shaft. Every time only one comes loose, then i cannot keep the other from just turning the shaft.
hanksled is offline   Reply With Quote
Old 04-04-2005, 10:10 PM   #2 (permalink)
Impact wrench (air wrench) is the easiest way.
Old 04-05-2005, 12:47 AM   #3 (permalink)
sesnopro
four gear pinned
sesnopro's Avatar
you will probly end up buying a new cross shaft.
http://www.hiperf.com/
Old 04-07-2005, 02:04 PM   #4 (permalink)
If you do not have an air wrench, only hand tools, a large pair of vicegrips clamped on the overshaft will generally hold ot so that you can turn the other bolt out. It helps if you tignten the one in that you started with and loosen the other one first.
Old 04-10-2005, 11:29 AM   #5 (permalink)
hanksled
hanksled's Avatar
thanks all....a lot a heat, and air gun did the trick:
