Snowmobile has no middle speed - Snowmobile Forum: Your #1 Snowmobile Forum
Old 02-09-2013, 05:33 PM   #1 (permalink)
schroeder57's Avatar
Its either slow or all the way full throttle. At top speeds it runs great but I turn a corner and its bogs, then accelerating is rough bogging. Then I get the throttle all the way to the bar and the high speed kicks in and then it runs good... until I slow down again.
Arctic Cat El Tigre 1981
Any help is appreciated!
schroeder57 is offline   Reply With Quote
Old 02-09-2013, 05:52 PM   #2 (permalink)
I would start with cleanning all the jets in the carb. Then sinck them. Then clean the clutches and check the center to centers. And wirth a new belt I would get it as tight as possible!
Old 02-09-2013, 08:36 PM   #3 (permalink)
The carbs are as clean as can be and i cant really see what is goin on with the belt when drivin, i dont really want to mess with that. I dought it is the belt because it is bogging
Old 02-09-2013, 10:00 PM   #4 (permalink)
Grudman
Grudman's Avatar
Check your boots for an air leak. Sounds like you have a vacuum leak some where that's why it bogging.
Sucking in air causing a bog. Until wide open throttle were it not effecting the air to gas ratio!
Grudman
Old 02-10-2013, 08:25 AM   #5 (permalink)
Mesure the center to center on the clutches, and then put a carpenters square across the plugs to the driven!
Old 02-13-2013, 01:40 PM   #6 (permalink)
This sounds like it could be influencing the situation. My boots are cracked and there is sealer on the sides of them but I should probably add more. It has been a long time since the sealer was put on. Thank you
Old 02-13-2013, 01:53 PM   #7 (permalink)
Replace them.
Old 02-13-2013, 02:48 PM   #8 (permalink)
joshkidner's Avatar
yes, replace them. they are not expensive! if it is still too lean adjust the air screws!
