did it on my wifes. very simple. just make sure that you use a sealant that is rated for gas when putting on cover or it may leak when riding and gas is sloshing around.
There is a local guy that needs a fuel pump so I was thinking of selling him my good one and asking if I can have his broken one. Seems to me that this would work as well as anything to block the hole off.
Current fleet...
2004 MXZ 500SS
2000 Z370
2003 Pantera 550
1998 ZL500
you can try it. its been so long since i did my wifes zl that i dont remember if you will clear the cowling under the handle bars. efi-carb may be slightly different but i'm not sure.
