97 cat rev to high? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-17-2013, 09:55 PM   #1 (permalink)
97 cat rev to high?
I have a 1997 Arctic cat cougar 550 just re-built hole top end. Sled is idleing at 1000 rpm and hitting 3000-3500 rpm when clutch engages. This is normal right? Please let me know any help would be great. Thank's
northmainer is offline   Reply With Quote
Old 01-17-2013, 10:05 PM   #2 (permalink)
My 95' Cougar idles at 2-3000 and engauges at the touch of the throttle. My 97' Zl 440 idles at 1500 and engauges at 4500. I think yours is fine at that.
kylerding is offline   Reply With Quote
Old 01-17-2013, 11:41 PM   #3 (permalink)
Idle should be 1500 to 1800 rpm.
Old 01-18-2013, 07:03 AM   #4 (permalink)
Yeah idle and engagement might be a bit low, not to worry it may idle a bit higher as it breaks in! You did add a bit of extra oil to the gas? You have cleaned the carbs?
Old 01-18-2013, 09:14 AM   #5 (permalink)
Re: 97 cat rev to high?
Yes I did put a little mixed gas so it did not run dry on first start, and yes carbs have been cleaned.
Sent from my YP-G70 using Snowmobile.com App
Old 01-18-2013, 04:53 PM   #6 (permalink)
1997 cougar
Could it be having idle problems do to the silencer boots being off (from air box to the carb). I didn't run it in the snow with them off just on a stand.
Old 01-19-2013, 09:19 AM   #7 (permalink)
The air box will actually make it run a bit richer.
