01-16-2013, 06:31 AM
#21 (permalink)
ordered a pressure test kit online, will post results when it arrives next week prob.
01-16-2013, 07:32 AM
#22 (permalink)
Presure test or Compression test?
A presure test would be block off plates and be to test the seals of the motor!
01-16-2013, 09:37 AM
#23 (permalink)
Sorry, compression test, to test each cylinder. Also I got the sled started on 2nd pull, so whatever was causing the high idle I must have resolved.
01-16-2013, 09:41 AM
#24 (permalink)
Off subject but where's a common place to take shocks for rebuild, and cost/durability compaired to replacing new for around $100
01-16-2013, 11:43 AM
#25 (permalink)
Rebuilding usually costs close to new unless you find a good deal on someone who does it. Not usually worth rebuilding unless they are high end shocks. Opinion
01-16-2013, 01:19 PM
#26 (permalink)
Standard fox rebuilds are $30... A cheap non-OEM is going to be over $100.
JBShocks snowmobile shock rebuilding
3) 2004 Yamaha Warrior
4) 2006 Yamaha Nytro
01-18-2013, 04:59 PM
#27 (permalink)
ok, you guys called it, ive got 87 psi and 90 psi...
01-18-2013, 06:04 PM
#28 (permalink)
top end kits
I can get spi piston/top end kit for $200, wiseco for $223, or oem $255, who's got opinions?
also... is it a good idea to do anything else, like crank shaft oil seal ect, that's easy to do when doing a top end
01-18-2013, 06:38 PM
#29 (permalink)
Re: 98 arctic cat zr600 efi starting/running issues
It would b a great idea to put new seals in if you got it tore down. I have two 98 zr 600 one with 8000+ miles with no rebuild and the other with 6000+ wih one if your in there do it all
Sent from my LG-AS730 using Snowmobile.com App
01-18-2013, 10:35 PM
#30 (permalink)
I'd go wiseco, and always give the sled a proper warmup...
If you do anything past the top end, you have to pull the motor and split the case. Not a bad idea, but also 10x more work. Just doing the top end is a 2 hour job at most.
01-19-2013, 05:55 AM
#31 (permalink)
Actually, I would recommend the SPI kit over Weisco due to the fact that they are a cast rather than forged and will be more forgiving to the person who may occasionally forget to provide sufficient warm up time,
01-22-2013, 02:15 PM
#32 (permalink)
update
hey guys, I pulled the cylinders out, and if recall from testing I posted before they were 84psi and 90 psi and ive got to say everything looks really good yet, sleeves and pistons look great surprisingly, should I just get replacement gaskets and piston rings and call it done?
01-22-2013, 02:20 PM
#33 (permalink)
As long as the pistons do not show signs of skirt damage/wear, use them again.
01-22-2013, 02:51 PM
#34 (permalink)
yea they look pretty good, nice and smooth. can the rings alone be that much of a problem to where I was only getting 84 and 90 psi? or combined with gaskets possibly leaking
01-22-2013, 02:55 PM
#35 (permalink)
and what kind of lube/grease should I use on the pistons
01-22-2013, 04:02 PM
#36 (permalink)
Just use some of the same oil that you put in the oil tank.
01-22-2013, 04:15 PM
#37 (permalink)
personally I would run a deglazing hone on the cylinders before you put it back together. this will help the rings to seat better.
01-22-2013, 04:31 PM
#38 (permalink)
Dump a bit of oil down into the cyls. And pull it over until it is covering the whole wall.
01-22-2013, 04:59 PM
#39 (permalink)
What's a deglazing hone? Is that a job for a machine shop?
01-22-2013, 09:17 PM
#40 (permalink)
ok, I understand what it is now, and I can just use my cordless drill which is 1400 rpm, now should I be using a 3 in hone brush or a bit bigger for the factory 78mm bore?
