AC ZL550 ESR drive bearing change question
Hi all,
I've undertaken the job to replace my lower drive bearings after the speedo side bearing failed.
After reassembling the dropcase gears/cover I looked under to set the lock collar on the speedo bearing and noticed that it is roughly shifted 1/16" towards the dropcase from where it was originally.
Is this an issue? Should I take apart the dropcase and try and shift it back somehow? Thanks much,
Sent from my SCH-R530U using Snowmobile.com App
