99 zr 700 gearing - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 26 (permalink) Old 01-08-2013, 11:30 AM Thread Starter
04firecat700's Avatar
99 zr 700 gearing
picked up a 99 zr 700 carb... seems like the gearing is way to high for the sled has anyone had any luck gearing this sled to wake it up on the bottom end?? top end aint to big of a deal to me 80- 100 is fast enough for me just looking for more kick in the butt!!
04firecat700 is offline
post #2 of 26 (permalink) Old 01-08-2013, 01:33 PM
93Wildcat700's Avatar
1999 was 24/39 2000 was 23/40 So 2000 gearing would give you a bit more bottom end
You could run 19/40 Powder special gearing but that would be a bit much depending on track size. It shouldnt lack bottom end.
My buddies 99 with that same gearing and a single pipe will almost flip over backwards if you pin it from a get go. his sled is 100% stock except he has a new primary...
maybe you have clutching issues?
1993 Wildcat 700 EFI- river runner
2000 ZRT chassis/Wildcat 700 EFI motor swap. Stock lol
93Wildcat700 is offline
post #3 of 26 (permalink) Old 01-08-2013, 05:21 PM
Quoted: 142 Post(s)
The 23 40 would be good, even 23-39 or 22 39!
kccats is offline
post #4 of 26 (permalink) Old 01-08-2013, 06:36 PM Thread Starter
Well a 02 zr 500 is even with me he geared down one tooth but still lets be real its a 700 vs a 500
Sent from my DROID BIONIC using Snowmobile.com App
post #5 of 26 (permalink) Old 01-08-2013, 06:37 PM Thread Starter
Peak rpm is like 7800 seams like its pulling a boat ankor
post #6 of 26 (permalink) Old 01-08-2013, 06:56 PM Thread Starter
It also has red primary and yellow secondary spring
post #7 of 26 (permalink) Old 01-08-2013, 07:33 PM Thread Starter
Clutching could be issue dead stop punch belt slips down into bottom of secondary
post #8 of 26 (permalink) Old 01-08-2013, 07:53 PM
The Arctic Cat spec. for max rpm for a 2000 ZR 700 is 7900 to 8100
How does the belt/ clutches look? are they old? does the belt ride 1/8 above the secondary just sitting there?
you could just move your secondary spring to get 200 more rpms but that's likely a band aid for a real issue. Im sure others will chime in
post #9 of 26 (permalink) Old 01-08-2013, 08:04 PM Thread Starter
Yes belt rides 1/8 inch above and yes I'm sure clutches are possibly worn it has over 6000 miles on it.. Just makes me want to set it a flame getting beat by a 500
post #10 of 26 (permalink) Old 01-09-2013, 06:08 AM
Quoted: 142 Post(s)
As I mentioned on the other thread, Start with a compression test! Next would be the reeds! Then go threw the clutches!
kccats is offline
post #11 of 26 (permalink) Old 01-09-2013, 06:30 AM Thread Starter
Compression is 130 on both cylinders.. If i look at the reeds what do i look for ?
post #12 of 26 (permalink) Old 01-09-2013, 06:47 AM
Quoted: 142 Post(s)
The reeds are on the underside of the cyl!
Have you mesured your center to centers? (12.2 12 1/4" works)
kccats is offline
post #13 of 26 (permalink) Old 01-09-2013, 06:52 AM Thread Starter
So the reeds aren't behind intake boots? And where do i measure?
post #14 of 26 (permalink) Old 01-09-2013, 07:34 AM
Does it also have 54gr weights in it?
Are the buttons in the secondary in good shape?
Have you checked the spring in the secondary is not broken?
If you had it apart,did you give the anchor plate the 1/3 twist needed to pretension the spring?
post #15 of 26 (permalink) Old 01-09-2013, 11:40 AM Thread Starter
As far as weights il have to look and i had secondary apart last night and spring is not broke and yes preloaded tension i believe there a problem there some where cause i can't punch it from sit still sucks belt right down
post #16 of 26 (permalink) Old 01-09-2013, 04:28 PM
Then the spring is no good [too weak].
post #17 of 26 (permalink) Old 01-09-2013, 08:27 PM Thread Starter
Is there a clutch kit or gear setup to wake this sled up?
post #18 of 26 (permalink) Old 01-09-2013, 09:09 PM
Fix the secondary!! That will solve the problem.
post #19 of 26 (permalink) Old 01-13-2013, 02:13 PM Thread Starter
Think i found the problem...motor mounts were loose and hole motor was shifting
post #20 of 26 (permalink) Old 01-13-2013, 02:49 PM
That will certainly contribute to the problem.
How much clearance is there between the engine and torque stop [behind the clutch]?
