99 zr 600 top speed of 70 mph - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-06-2013, 07:19 PM   #1 (permalink)
I just bought a 99 ZR 600 carbed for $1100 its suppose to have a rebuilt top end new bearings in the chaincase and suspension. It must have clutch kit because it takes off at 5500 rpm. It also has a D&D power breather, aftermarket can, and some D&D suspension stuff. It performs very well for a 600 it pulls wheelies well and beats my buddys 2000 polaris 700 out of the hole. The only problem I got with it is it will only do 70-75 mph at WOT. The guy says its got a new secondary and it has a purple spring dont know if this is the cause of the problem. Any Ideas how to correct this?
ryanhermann is offline   Reply With Quote
Old 01-06-2013, 07:26 PM   #2 (permalink)
smokingcrater's Avatar
how about gearing? I'm running the full mountain gearing on my zr and it probably won't get much above that, which I'm perfectly fine with. It gets there in a hurry!
3) 2004 Yamaha Warrior
4) 2006 Yamaha Nytro
Old 01-06-2013, 07:58 PM   #3 (permalink)
I dont know it could be it does seem to run a lot of rpms all the time. I 'll try getting a hold of the guy I bought it from to ask.
Old 01-06-2013, 09:03 PM   #4 (permalink)
I'd just pop open the chain case. You don't know how long that oil has been in there, and when its open, you can take a look at the gears, as well as the condition of the chain.
Old 01-06-2013, 10:17 PM   #5 (permalink)
mxz700brp's Avatar
Im still new in the snowmobile world but id say the sled is geared a lil lower then stock...
mxz700brp is offline   Reply With Quote
Old 01-07-2013, 07:17 AM   #6 (permalink)
It should have 20-39! I would also look at the belt and the center to center(12 1/4")
Old 01-07-2013, 08:02 AM   #7 (permalink)
What is the peak rpm at wide open throttle?
Old 01-09-2013, 04:56 PM   #8 (permalink)
I think max rpm was just above 8000 rpm dont remeber exactly what it was. I might pull the chaincase cover with this damn 40 degree weather gonna have to wait for more snow now to test anyway.
