93 wildcat 700 efi - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-31-2012, 11:57 PM   #1 (permalink)
93 wildcat 700 efi
the sled rode fine then tried again the next day no power? I check the battery it was fine i check the fuse it was shot so i replaced it still no power. I checked the dc voltage regulator had power from positive wire but no other connection...does anyone have a wiring diagram that is 700 efi specific with out starter?
sargesffs is offline   Reply With Quote
Old 12-31-2012, 11:59 PM   #2 (permalink)
93 wildcat 700 efi
also I'm looking to upgrade the suspension to something with more travel what suspension would transfer over nicely with minimal alterations. I'm a machinist so i made my own riser for it. but now i need more suspension.
Old 01-01-2013, 05:31 AM   #3 (permalink)
Got pics of that riser?
A TSL skid will bolt in with new holes drilled 2" forward of the existing ones [puts them right on the edge of the reinforcing plates].
I would have to scan the specific page, don't have one available just now.
Old 01-02-2013, 04:44 AM   #4 (permalink)
Are you saying no spark or just No power as in wont pull itself off idle?
Old 01-02-2013, 02:35 PM   #5 (permalink)
right now i have no battery light and you dont hear the fuel pump kicking in.
Old 01-02-2013, 02:39 PM   #6 (permalink)
Check that the relay on the back of the ECU plate is working.
Also, there is a fuseable link that can go bad and cause the problem too.
It is on the Red + wire and splits into a green and brown wire.
Old 01-02-2013, 03:02 PM   #7 (permalink)
this why ive been trying to find a manual, I can work on harleys but sleds im just getting into. I have 2 pos wires to battery pos and 3 to neg. I replaced the inline fuse with a new blade style have power on opposite side of fuse so i know thats done right.
Old 01-02-2013, 03:03 PM   #8 (permalink)
what does the relay look like?
Old 01-02-2013, 03:04 PM   #9 (permalink)
if the kill switch is bad would the battery light still light up or no?
Old 01-02-2013, 03:36 PM   #10 (permalink)
The relay is a brown box for the fuel pump and the injectors are fed through the blue one.
The battery light would come on only if the kill switch was broken in the run position.
This sled uses a closed to run system which means all switches have to be closed to operate. If one of them is open, the engine will not run.
Old 01-02-2013, 05:15 PM   #11 (permalink)
What kinda of rear suspension is on your wildcat looks like it sits alot high than mine?
Old 01-02-2013, 05:16 PM   #12 (permalink)
So should i try to jump the kill switch?
Old 01-02-2013, 06:16 PM   #13 (permalink)
just jumped kill switch and nothing still
Old 01-02-2013, 07:32 PM   #14 (permalink)
Dezlemke's Avatar
Rj has an 01 zr under his wildcat
"The further one goes, the less one knows. The more one trades, the more one plays."
95 z440 (first sled, now my little bros)
2000 zl500
Dezlemke is offline   Reply With Quote
Old 01-02-2013, 07:59 PM   #15 (permalink)
Rczr600rider's Avatar
I put a 1997 ZR 580 rear skid in a 1993 EXT 550 with no alterations at all. It didn't sit up as high as RJ's Wildcat, but it picked it up a couple inches and it rode nice.
Old 01-03-2013, 07:39 AM   #16 (permalink)
Actually, it from an 01 ZRT, fully coupled which makes it ride like it's a plush carpet.
Old 01-03-2013, 05:48 PM   #17 (permalink)
anyone find a 93 wildcat 700 efi specific wiring diagram
Old 01-04-2013, 06:09 AM   #18 (permalink)
I have a hard copy shop manual that I got through a dealer, well worth the $30 it cost.
Old 01-04-2013, 07:21 AM   #19 (permalink)
Old 01-04-2013, 11:29 AM   #20 (permalink)
i can not blow image up without losing clarity
