Head lights, back light, and heated handle grips stopped working ZL600 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-29-2012, 04:18 PM   #1 (permalink)
Yesterday, I purchased a 2002 model ZL600 EFI SS. After riding about an hour the front light, back light, brake light, and heated handles stopped working. I checked all the wiring connections I could find and did not find anything loose or cut. Does anyone have any other suggestions?
NE SoDak is offline   Reply With Quote
Old 12-29-2012, 05:07 PM   #2 (permalink)
You might want to ohm the stator, specifically the lighting coil circuit.
Hopefully Blaine will chime in, he's the guru on stators.
Current fleet...
2004 MXZ 500SS
2000 Z370
2003 Pantera 550
1998 ZL500
Old 12-29-2012, 05:17 PM   #3 (permalink)
Or the voltage regulator quit.
1999 Ski Doo Grand Touring
Old 12-30-2012, 05:53 AM   #4 (permalink)
Look at the bulbs, it they are all blown, then the regulator has failed.
Old 12-30-2012, 02:01 PM   #5 (permalink)
Thanks for the input. A friend of mine and I did some further looking today. I did confirm that the bulbs are good. We did not do an ohm reading on the stator as it looked like it was going to take an hour or so to take it off. We did do an ohm reading on the regulator. It came back with a reading of about 0.7. Should this be at zero?
Old 12-30-2012, 07:12 PM   #6 (permalink)
The guy working with me called this a responder, I am not sure if this is the same as a regulator.
Old 12-31-2012, 06:39 AM   #7 (permalink)
Look at Blaine's video on stator checking. Very helpful and informative.
sae1722 is offline   Reply With Quote
Old 01-12-2013, 02:13 PM   #8 (permalink)
polymoog's Avatar
My b/f had something similar once, lights and handlebar warmers quit. (ZL600 from 1999). Turned out he had wires touching metal parts in 3 different places, against the exhaust (because some of the plastic clips that hold the wiring in place against the hood were missing so the cables hung loose and the plastic sleeving had melted), behind the engine (bad wiring repair/mod), and also under the seat, where the wiring goes to the lights at the back (bad wiring repair/mod). So you might have something like that with yours, esp if you just got the sled, and you don't know what the previous owner has been doing with it ...
1990 Arctic Cat Jag 440 AFS / 2002 Arctic Cat Mountain Cat 600 EFI
polymoog is offline   Reply With Quote
Old 01-13-2013, 04:55 AM   #9 (permalink)
Thanks for the feedback everyone. After checking all the wiring a few times and replacing the voltage regulator rectifier, I am now going to have a serious look at the stator. I did place an ohm meter on it and it did not give the results it should have.
Old 01-13-2013, 06:26 AM   #10 (permalink)
You can also test the voltage coming right out of the motor. It should be 30-40VAC before it goes into the regulator. If V is low, bad stator.
Old 01-13-2013, 08:19 AM   #11 (permalink)
lots of good tips here. when I turned on my headlights, the engine would bog, I found that the current was jumping into the body, lil tape and it was fixed.
87Pantha is offline   Reply With Quote
