Where can I get a needle and seat spring clip? - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-26-2012, 06:59 PM   #1 (permalink)
I was rebuilding the Mikuni VM 38 carbs on my 98 ZL500 and I lost one of the spring clips that prevent the float needle from dropping out of the seat. I checked the Cat parts catalog and found that it's only available as a needle and seat set at a cost of around $40.00 CDN! Does anyone know where I can get one at a reasonable cost?
The picture is from the other carb with the clip still installed.
Current fleet...
2004 MXZ 500SS
2000 Z370
2003 Pantera 550
1998 ZL500
Old 12-26-2012, 07:46 PM   #2 (permalink)
You can run without it if you had too! But try HPE and get an aftermarket for like $10!
