mikuni vm38 carb specs - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-24-2012, 01:55 PM   #1 (permalink)
anyone know what the carb adjust specs are for theses carbs
CRCINDY400 is offline   Reply With Quote
Old 12-24-2012, 05:26 PM   #2 (permalink)
I just fix 'em...
IRONDOG's Avatar
Idle air mixture screw lightly seated then turned 1.5 turns out. Jet needle clip in middle notch on needle. These are basic starting points and are the only two calibrating "adjustments" that can be made without changing components. All other tuning requires changing jets, slides, etc. and is specific to each application.
www.snowmobileswapmeet.com
