96 ext 580 efi - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-23-2012, 11:19 PM   #1 (permalink)
96 ext 580 efi
hi all ive got a weird driveability issue w/ my ext 580 efi after 10-15 min of ride time loss of pwr, bogs like a stuck pig ,but will rip good until problem occurs charge coil 1 tests low when cool any suggestions?
mopardad4406 is offline   Reply With Quote
Old 12-23-2012, 11:21 PM   #2 (permalink)
Grudman
Grudman's Avatar
Could be a couple of things Fuel pressure needs to be a steady 36 psi. Stator could be going.
Grudman
Old 12-24-2012, 04:51 AM   #3 (permalink)
Have you tested it warm?
If it's reading low cool, then it may be ready to fail.
Blain1 can get you a good price for a reman stator if needed.
Old 12-24-2012, 05:59 AM   #4 (permalink)
Yep do the fuel test as well as test the stator when warm! Get back to us with what you find! Also test the compression @WOT!
Old 12-24-2012, 07:53 PM   #5 (permalink)
thanks for the info will do the testing,still learning about these 2 stroke driveability diags & repairs, hopefully this will come to a good diag
Old 01-05-2013, 02:53 PM   #6 (permalink)
Dirtman's Avatar
so how much for a new stator RJ , i was the guy that found a broke thermostat .,, yea not it , ran good till i got 2 mins down trail and BAM , bogging again ,,
check stator readings and 44, 551 605 ,,, that cant be good
Dirtman is offline   Reply With Quote
Old 01-06-2013, 05:37 AM   #7 (permalink)
Blain1 has them for {I think} around $150.
Old 01-06-2013, 11:53 AM   #8 (permalink)
Dirtman's Avatar
that was just after it was running and bogging .
so what are the ohms 45 450 500 < when cold > correct ?
