need help with my bearcat 550!! - Page 2 - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-21-2012, 05:16 AM   #21 (permalink)
The retainer clip should be on the middle notch.
To get the choke slug out, you will need to use some penetrating oil and let it soak for at least 24 hours, repeat as necessary to get it out.
Old 12-21-2012, 05:51 AM   #22 (permalink)
Take the other side apart and be sure they are the same! Look VERY carefully for the Very small E clip!
Old 12-22-2012, 02:44 PM   #23 (permalink)
another question! witch side i but the little magnet!?? those it matter? one side is positive and other are negative? If i use a ohm meter and i test the connection need to be close when the feeder is not apply wright??
madmaths is offline   Reply With Quote
Old 12-22-2012, 06:18 PM   #24 (permalink)
You can bypass the magnet switch!
Old 12-22-2012, 06:35 PM   #25 (permalink)
ok magnet are fine!! I figure and adjust with a ohm meter!!
My bearcat is back alive!! and better than ever!!! thanks so much guys!! your are very helpfull!!! THANKS!!!!
