Hi guys, I finally got her out today after a few little adjustments:
I replaced the bushings in the primrary weights, put in a yellow/green spring went to a BR8ES plug and dropped the mains to 190.
The sled ran much better. It kicks in at 4500 now. It does not seem to be to violent of a start. The plugs were a little light in color. I will be going back to the BR9ES’s.
RJ my peak RPM is 8500. That seems high. Is it?
I also put the secondary spring back to the middle hole. How does the hole change max RPM?
I have a Huge 2” lug track. I think this is where most of my issues come from. Would a different helix compensate for the heavy track? I have a 49* on it now. It still seems a like a bit of a dog out of the hole.
Thanks everyone for your help!!!
Brad
