Clutch question - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-09-2012, 05:32 PM   #1 (permalink)
Clutch question
Hey guys I need help with some play in the driven clutch. There is about an 1/8" horizontal play if I move it side to side. The shaft doesn't move just the sheaves. Is this normal or do I need to move the adjusting collar against the stationary sheave. I measured the offset and its good where it is. I attached an image to show if I remove the small washer (#10) in pic, I can get rid of the play. Can someone check their cat and see if you too have this play? The sled is a 78 panther 5000. Thanks
yammi1 is offline   Reply With Quote
Old 12-09-2012, 09:48 PM   #2 (permalink)
That is normal, it allows for some variability in the offset. [self aligning feature]
Old 12-10-2012, 07:03 AM   #3 (permalink)
Ok thanks RJ
