Originally Posted by bwit22
where is the fuse located.. and if i hook up a battery charger directly to the starter it spins but if i do it on the solenoid it just clicks..
Follow the wiring harness down from the ignition switch. The fuse with be located in a fuse holder like in the thumbnail I attached to my 1st post. Solenoids do click when they are working, if it doesn't click, then you have a problem.
