95 Arctic Cat ZR700 Spark Issues - Snowmobile Forum: Your #1 Snowmobile Forum
Old 12-03-2012, 06:47 PM   #1 (permalink)
DG88fan's Avatar
Well the title says it all. My Arctic Cat does not have spark. I searched the issue and bypassed the kill and the Throttle safety and the tether as well. Still nothing. I then turned my attention to the cdi box, the single bulleted conector leading to the box needs to be grounded correct? So I ran a jumper wire from that connector on the box to the frame on the sled. When I did that I got spark. So my question is this, does this mean that the box is bad? Stator? Switch? The sled will start and run well with a ground jumped to the box. What am I missing?
I assume that since the sled will run well with the jumper wire on the box that the stator is working as it should. When I have the jumper wire on the sled I cannot shut the sled off with the key switch, so it must be connected to that circut somehow.
Any help would be appreciated.
1995 Arctic Cat ZR700
1996 Arctic Cat EXT580
DG88fan is offline   Reply With Quote
Old 12-03-2012, 08:12 PM   #2 (permalink)
So what about the 4 way connector? I believe that single wire IS your kills! I asume it is Black or is it BROWN?
Old 12-03-2012, 08:44 PM   #3 (permalink)
DG88fan's Avatar
I beleive it is black but I would have to check again to be sure. So you beleive that the single wire is for the kill switch, which does make sense. I will check and ask some more questions tomorrow.
Old 12-04-2012, 05:37 AM   #4 (permalink)
Blaine1's Avatar
NOt sure which wire you are referring to....there is a ground wire for both the stator and the cdi box. Is the one on th eCDI box broken off and then you grounded it?
Wanted: Dead Stators PM me.
Testing Cat triple stators
Jumper wire bypass
Old 12-04-2012, 03:15 PM   #5 (permalink)
DG88fan's Avatar
Well there is a small black wire coming out of tge cdi unit. It connects to a wire that looks as though it goes into the stator shroud.
Old 12-04-2012, 05:56 PM   #6 (permalink)
Ok is there 2 other wires some where in the harness that are cut? If you hook them together what do you get?
Old 12-04-2012, 08:12 PM   #7 (permalink)
DG88fan's Avatar
As far as I can see there are no cut wires. I have taken apart the main connectors and have cleaned them. I just ordered a service manual on it so hopefully I will be able to make better sense on the wiring system.
