99 zl500 clutch questions - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-25-2012, 04:05 PM   #1 (permalink)
-PREMIUM MEMBER-
firedude26.'s Avatar
99 zl500 efi, it engages real hi, 5000 rpms. i wanna know if it has stock springs in it? they are both yellow, can someone tell me what stock was??
thanks
2005 Arctic Cat Sabrecat 700LX
2000 Arctic Cat ZL580 ESR
1999 Arctic Cat ZL500
1997 Arctic Cat 580EXT... RIP
Carleton, MI
Ride area: Long Lake, MI
firedude26. is offline   Reply With Quote
Old 11-25-2012, 04:27 PM   #2 (permalink)
Stock is yellow/white with 46.5 gr arms,yellow with a 51* felix. The engagement is 4800rpm!
Old 11-25-2012, 04:47 PM   #3 (permalink)
-PREMIUM MEMBER-
wow 4800? thats seems kinda high but if anyone would know it would be you! i have a yellow one and i dont see any white on it, there is a difference there right? also would you know the part number for the yellow/white one???
thanks again!!
Carleton, MI
Old 11-25-2012, 06:02 PM   #4 (permalink)
0646-229
Old 11-25-2012, 06:43 PM   #5 (permalink)
-PREMIUM MEMBER-
ok the arms are right, i think the spring is also, there is a dirty looking white looking mark on it but no numbers. i have a zl580 and it doesnt engage that high, is there another spring i can use to easy up the engagement?
Carleton, MI
Old 11-25-2012, 07:41 PM   #6 (permalink)
The 580 engages at 3500! The 500 will be a dog at 4500! Go threw the clutches and clean everything! Then get your center to centers right! 12.2"(12 1/4"works) Then a new belt and get it as tight as possible!
Old 11-25-2012, 07:51 PM   #7 (permalink)
-PREMIUM MEMBER-
sorry for all the ?'s but when you say get it as tight as poss, does that mean adjusting the secondary tighter so the belt rides higher on it?
Carleton, MI
Old 11-26-2012, 07:52 AM   #8 (permalink)
Yes! Once you have the motor moved to 12 1/4" from the secondary shaft. There are 3 shims in between the shevs of the secondary. Try removeing a thick and put it all back together and see if the belt squweels. If not try takeing out another? Once it squweels put a thin back in! This alone will Really help your performance!
Old 11-26-2012, 08:15 AM   #9 (permalink)
-PREMIUM MEMBER-
GREAT i have the adjustable type on this one, so i can adjust it to where i need it.
thanks
Carleton, MI
Old 11-26-2012, 08:20 AM   #10 (permalink)
Get it to grab a bit and then back it off a bit!
Old 11-26-2012, 08:30 AM   #11 (permalink)
-PREMIUM MEMBER-
Thanks kc!!
Carleton, MI
