Oil Pump Question - Snowmobile Forum: Your #1 Snowmobile Forum
Old 11-24-2012, 04:38 PM   #1 (permalink)
Oil Pump Question
I was lucky enough to score a wrecked sled with a good motor to replace the blown motor in my 91 Prowler. I switched the engines out today but I forgot to bleed the oil pump. I have put 50:1 mix in the tank for start up. Will the oil pump bleed it self while I run the 50:1 mix out or do I need to bleed the pump?
SB49 is offline   Reply With Quote
Old 11-24-2012, 04:47 PM   #2 (permalink)
Bleed the pump! There is a screw in the pump to loosen or remove till oil comes out!
Old 11-24-2012, 05:37 PM   #3 (permalink)
ridegreen's Avatar
Gotta bleed it or you will be back at square 1.
Old 11-24-2012, 07:09 PM   #4 (permalink)
It's possible that the air will bleed out, but it's also possible that the pump will rotate and not move any oil because of the air bubble. I wouldn't take the chance.
Old 11-25-2012, 07:24 AM   #5 (permalink)
I was afraid I would have to bleed it. Wish I could get my hands on the idiot engineer at Arctic Cat that thought it would be a good idea to put the oil pump on the bottom of the engine where you cant get to it to do service.
Old 11-25-2012, 07:28 AM   #6 (permalink)
There really isn't any service to it! Pull the carbs it's right there!
Old 11-25-2012, 08:28 AM   #7 (permalink)
It's pretty easy if you have an extra hinge in your wrist...
And it's a walk in the park compared to the Polaris IQ sleds. You have to use a mirror and a special tool to adjust those!
Old 11-25-2012, 07:23 PM   #8 (permalink)
I hear you Dan, got it done, only took about an hour and a pint of pricy two stroke oil on the garage floor to get it done. Would have only taken about 45min if I had a extra joint in my wrist. I stick with my rant if you have to adjust it, bleed it, check it, tune it, "IT" should be some where you can see it!
Old 11-25-2012, 07:57 PM   #9 (permalink)
AMEN to that!
