EXT 580 bogs
Hi guys, my EXT Boggs out off idle. I have tried everything:
Carbs cleaned
Primary clutch cleaned and rollers replaced
Diddled with the secondary spring settings
Stator changed out
New bearings in driveline
One thing I have not done is replace the home made can on this thing. It is just a piece of pipe where the box should be. Do you think this could be my issue?
I am waiting for snow to try it with the new bearings. The PTO side bearing was kinda trashy, hopefully that will make a difference too.
Thanks,
Brad
